| Home > 998cc > spool up | |||||||
26th Oct, 2006 at 09:04:53pm
26th Oct, 2006 at 09:35:19pm
Well our 998 turbo with a stck metro turbo T3 got to max boost (about 18psi) at about 4k. This is not a bolt on job though. You need to concider lots of things not least compression ratio and pistons.
http://www.twin-turbo.co.uk
26th Oct, 2006 at 09:57:36pm
ive just looked at the website for your car, you didn't suffer two head gasket faliures at gursten on the 26/27th did you or at least not run in the afternoon on one day. i'm sure i came up and asked about the spec and was damn impressed that you were posting the same times as the N/A 1380's.
26th Oct, 2006 at 09:59:25pm
27th Oct, 2006 at 08:00:07am
Yes that was us. The head gasket failures have been solved now and are not normally a problem. It was a combination of a blocked rad and a recessed brass incert. http://www.twin-turbo.co.uk
