Home > Help Needed / General Tech Chat > fittin a 1293cc t3 engine 2a 1976 mini 1000
1976_mini
Member #: 259
grays, essex
plz help lads,
is ?300 a gud price for a working 1293 engine with a t3 turbo runnig 120bhp? also i want 2fit it 2my 1976 mini 1000 so apart from breaks ne otha mods i gotta do? oh n one more fing, do i have 2fit a turbo box or not?
fanx for the help lads
it may b small but it purfectly formed
http://photobucket.com/albums/v340/1976_mi...roject%20turbo/
1380Turboman
Member #: 221
Definitely sounds like a fair price to me!
Paul
1976_mini
Member #: 259
grays, essex
so wot otha mods apart from breaks would i have 2do?
1380Turboman
Member #: 221
A turbo box is a must unless you go the mirage manifold route. This is a lot more expensive, but i think Iain and a few others are trying to organise a group buy so could work reasonable enough.
Your turbo engine will more than likely be running a verto setup with the later type starter. If you want to keep it like this, ur old mini clutch slave cylinder will need to be changed and the electrics modified for the starter, ignition coil and electronic dizzy.
Probably best to replace all the subframe mountings with polymer bushes etc.
PC.
1976_mini
Member #: 259
grays, essex
cheers for the advise ill bear it in mind
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Are you going to buy that engine? If not i know somone who will inspect it.
1976_mini
Member #: 259
grays, essex
yea i am goin 2buy it. wonna try n get it all up n running 4the next show!!!
1380Turboman
Member #: 221
You will also need to fit new large 8mm fuel pipes....with a return pipe to the tank. I had a hole drilled and the top of the tank and a small pipe welded into it.
1976_mini
Member #: 259
grays, essex
thanx for all the info turboman
