Home > Wanted > wanted in the mids or bring to a show, bolt on door bars for a SD roll cage
clubminiflip
Member #: 54
nr coventry
bolt on door bars for a SD roll cage, colour does'nt matter, i've posted on the chance someone may want to get rid of theres cheers
Carl
Member #: 95
liverpool-on-sea
personally id buy these new, as there not to expensive and also they have to be cut to size so if whos ever min theve been in has a different gap between the front and rear cage (which is possible i suspect) then you might struggle to fit them, just a thought
