Home > General Chat > Swift Tunes SW5 Cam....................
here is a link to swiftunes website for the SW5 Camshaft!
http://www.swiftune.co.uk/sw5.php
they make big claims *surprised*
any one tried on with a turbo motor ??? anyone !
JT
Member #: 637
Hertfordshire
i know that people like to use them in 998's. not sure about turbos.
they dont let the details of the cam out but i think its like a 997 cooper cam.
could be wrong though.
My build thread..
josh heres a link on the timing figures i posted a while a go on the SW5 and a few other cams
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=8343
just would like to know if anyone "maybe newbies" have tried this cam out ?
shane
Member #: 1246
Lowestoft, Suffolk.
Hi, Im currently using the sw5 cam in my 998, running a 1300 turbo head (10.5;1 cr), lightened and balenced bottom end, free flow exhaust manifold with full stainless rc40, flowed and matched maniflow inlet for twin inch 1 1/4 SU's, tailored dizzy, it produces a hearty 60bhp, it pulls from nothing, runs out of puff at 5500k, quite smooth drive tho, really enjoyable! have heard its very similar to the 997 cooper cam, when I asked them this on the phone the guy got VERY touchy. Could of choose a wilder and better cam for a few more horses but I happy for the drivability this provides.
Hope this helps.
Shane.
i've heard the SW5 is a fiesta profile.
andeh
Member #: 97
Near Daventry, midlands
110bhp on conservative rollers has been seen, 1460cc 5 port head with mg valves with said sw5 and 1.5:1 rockers. Its a ver good cam, but if you like that sort of thing there is a better to it already if you dont mind replacing the cam more often in the Morspeed 'Ph2' cam which has even more lift than the sw5 and only ever so slightly more duration. This is what im going to try in my turbo 998 and 1380
andeh have you got the timing figures or anyone for the morespeed cam?
Around 97/98 or thereabouts, when I started earning a few 壣 again. I replaced my cylinder head that had major cracks between the valve seats with a SW item. I had to revert to the cracked head due to problems with another head I had purchased mid 1995.
At that time, I also added a SW5 cam to go with the new head
So while I cant give a back to back comparison with an identical setup, the SW5 and SW head combo defo felt like a better performer.
My car was never near a dyno, and never made it to a strip in that format though. My old 1/4s were run with an Avonbar modified head ( which subsequently had larger ex valves fitted for PB time ) and MG metro cam.
Always using 1.5r rockers.
As it is, it will idle totally smoothly, pull WOT in 4th from around 1500rpm and is amazingly torquey at that, and rev cleanly to 7500rpm.
There were a few chugginess issues mid range, but that was fuelling related. No widebands back then to assist.
So I would say its an excellent cam. But then, so is an MG metro cam.
Obviously Ive never used the Ph2 cam or other more modenr grinds.
andeh
Member #: 97
All taken from Mr Dodds reference area on the ML Motorsport forum...
First off is the excellent Swiftune SW5 road cam, these figures are based on my observations based on 2 new examples I measured about 2 years ago. The figures are to be read as average of the 2,
Checking height: 0.016" @ lobe
Timing: (Intake): 16/48 (Exhaust): 52/12
Nominal lobe lift: (Intake): 0.281" (Exhaust): 0.281"
Duration (Intake): 244 (Exhaust): 244
Lobe centre angle (Intake): 106 (Exhaust): 110
Lobe separation angle: 108
Lift on overlap: 0.036"
Accuracy: Good
Next is the much under used Kent 246 a nice all round road cam that has a little more bite than the SW5, these figures are based on kents own specs, plus with my own additions looking at 1 cam.
Timing: (Intake): 18/54 (Exhaust): 54/18
Nominal lobe lift: (Intake): 0.285" (Exhaust): 0.285"
Duration (Intake): 252 (Exhaust): 252
Lobe centre angle (Intake): 108 (Exhaust): 108
Lift on overlap: 0.048"
Accuracy: Good
The Morspeed phase 2 (Fast road) Based on 1 example only;
Timing: (Intake): 20/52 (Exhaust): 56/16
Nominal lobe lift: (Intake): 0.305" (Exhaust): 0.298"
Accuracy: Good
This might also be of use, its a modern day Kent276 by morspeed, another very good cam!
The Morspeed phase 3 (trackday cam) Based on 1 example only;
Timing: (Intake): 27/63 (Exhaust): 63/27
Nominal lobe lift: (Intake): 0.315" (Exhaust): 0.311"
Duration (Intake): 270 (Exhaust): 270
Lift on overlap: 0.065"
Accuracy: Good
Edited by andeh on 28th Oct, 2006.
Data for the PH2.
On 23rd of Sep, 2006 at 05:27pm TurboDave said:
Above is an image of the data for the "MED T3" camshaft...
incidentally - exactly the same figures are used for the Avonbar Phase 2 camshaft (which i believe came out first)...
I found it by trawling through various old posts.
It has considerably more duration than the SW5 and a 110 degree LSA.
I'm using the SW5 in my N/A 1275 that I'm using to develope EFI.
It seems to work very well with the 2.76:1 diff.
It will cruise at 80 at 3600rpm and you can still hear yourself speak. Plus it returns 45mpg.
I don't think it is ideal for a turbo application. This is not based on any real experience, more on research on this forum. I think that it will need a higher LSA and more exhaust duration.
The Piper BP270i looks a better option. More like the MG N/A cam but higher lift and 110 degree LSA.
ive been offered a SW5 injection cam,
which is ok as im going to using MJLJ any way,but as said before is this any good for turbo use??
Moz
Its the last cam I used...I thought it worked great.
I know Nick Swift pretty well with 8 years of dealing with him. If he states it in his writings then based on my experience its true
Paul
Im not doubting Swiftune, but they claim 'well over' 100bhp on a 1380 with twin carbs and 1.5 rockers............
http://www.mlmotorsport.com/option,com_smf...opic,124.0.html
AC Dodd said:
This one is a 1380 as built by Swiftune racing its one of there classics, big engine mild cam(SW5) nice head, 1.5 Roller tip rockers, Twin HS4 SU carbs, cone filters/stub stacks, Carbs was fitted with a Custom ACDodd needles and RED springs.
Produced figures of 90.5bhp@ flywheel, and 86.7lbft @ 3500rpm respectively.
Here are the exact figures if anybody want to plot them, runs taken in 3rd gear, power at wheels was 81bhp peak.
Rpm Bhp Lbft
1500 20.41 71.46
2000 27.89 73.24
2500 35.71 75.03
3000 49.32 86.34
3500 57.82 86.77
4000 65.31 85.75
4500 73.47 85.75
5000 81.29 85.39
5500 87.41 83.47
6000 90.48 79.20
This engine also had leak down figures of 15%, 23%, 25% and 14%.
This was also the most powerful SW5 equipped car I have tested to date, though it should be it has the spec!!
