| Home > Help Needed / General Tech Chat > convert 8.4 brakes to 7.5 or 7.9 4 pots | |||||||
397 Posts Member #: 694 Senior Member Shropshire |
28th Oct, 2006 at 09:33:59am
First of all which is the best brake setup to use 7.5 vented or 7.9 vented system for track days? As far as my knowleage takes me the 7.9 vented setup should be the ultimate however I am under the impression that this will cause an issue with the fitting of 10 inch wheels, and may or may not be any better that the vented 7.5 setup. Is this true?
314 Posts Member #: 1311 Senior Member Yeovil, Somerset |
28th Oct, 2006 at 09:41:01pm
I am currently running 7.9 vented disks with alloy 4 pot calipers and have to say they are pretty good (with no servo). They went straight on to the standard drive shafts i had and run perfectly on my 10X6 rims.
28th Oct, 2006 at 09:52:19pm
Drive flanges okay if 8.4 Mini ones not if 8.4 Metro ones On 5th Sep, 2011 Vegard said:
29th Oct, 2006 at 09:18:31am
Minimad69
29th Oct, 2006 at 01:23:26pm
Stig
29th Oct, 2006 at 02:01:39pm
Bear in mind that apart from the vented disks being machined to 7.9mm the also need some 600 thou? removed from where they bolt to the mini drive flange, not a problem if you buy the disks modded, but i thought i'd save some money and mod the disks my self for my Kad 6 pots... much head scratching!!
