Page: |
Home > Help Needed / General Tech Chat > Hepolite 20832A Pistons? | |||||||
8297 Posts Member #: 408 Turbo Love Palace Fool Aylesbury |
13th Feb, 2007 at 01:54:46pm
On 12th of Feb, 2007 at 09:51pm fastcarl said:
i have used these early solid skirt mg pistons in the past, the ring pack i used was R21576V1, in fact i have a set of 4 in near perfect condition, that i have machined 13cc bowls into.and a new ring pack, carl Is that a hint that you may be willing to sell? Edited by matty on 13th Feb, 2007. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
6962 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
13th Feb, 2007 at 05:43:59pm
was it so obvious,lol.
282 Posts Member #: 1404 Senior Member The Netherlands |
13th Feb, 2007 at 06:27:03pm
you've got pm there is nothing wrong with a A-series that a turbo can't fix.
13th Feb, 2007 at 11:53:32pm
Ah they would of been ideal, need + 20's though! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
1547 Posts Member #: 2727 Post Whore Bicester |
5th Sep, 2011 at 02:48:58pm
Blast from the past, but is anyone using these in their turbo engines? just found a set in my garage 1972 998 TURBO SLEEPER |
4301 Posts Member #: 1321 Post Whore Wiltshire |
5th Sep, 2011 at 04:35:28pm
If you can get the compression down given their smaller dish I would use them, they certainly look sturdy. On 7th Oct, 2010 5haneJ said:
5th Sep, 2011 at 04:41:01pm
Cheers just need to find some new rings now 1972 998 TURBO SLEEPER |
10020 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
5th Sep, 2011 at 04:48:12pm
I would imagine that they are comparable to 21253's. Do they have oil slots or holes chris? If something is worth doing, it's worth doing half of. |
5th Sep, 2011 at 04:50:43pm
pretty sure they have holes, ill have to double check 1972 998 TURBO SLEEPER |
5th Sep, 2011 at 04:51:45pm
On 5th Sep, 2011 longy said:
pretty sure they have holes, ill have to double check so am I, I picked one up the other week! On 7th Oct, 2010 5haneJ said:
5th Sep, 2011 at 07:38:34pm
Just checked the pistons and they have four holes either side of the gudgeon pin. Rings seam to be a bit hard to find though, what are peoples thoughts on reusing rings, the rings are only 5000 miles old. 1972 998 TURBO SLEEPER |
5th Sep, 2011 at 09:18:43pm
I wouldn't.
2 Posts Member #: 12344 Junior Member |
24th Feb, 2024 at 11:25:43pm
I have 20832 pistons and need rings, do the R21576V1 fit? |
2486 Posts Member #: 1954 Post Whore Luton Bedfordshire |
28th Feb, 2024 at 07:03:08am
What I have found is that on some applications the same ring is used across multiple pistons, for example you may find that the compression and scraper rings are exactly the same on a +20 and +40 piston
Own the day
28th Feb, 2024 at 10:19:06am
The oil rings in the hastings set I had received are spot on.
29th Feb, 2024 at 03:11:38pm
well I had to match rings from different sets to fit the ring grooves if they match they match. if the profiles match they match.
Own the day
Page: |
