Home > Help Needed / General Tech Chat > dumpvalve questions
1976_mini
Member #: 259
grays, essex
never had any dealings with a dumpvale so im not quite sure whats going on, i bought the car with it allready on but i dont think its working as i cant hear it. ive included 2pics, the first one is the contense of my dump valve and the 2nd is how its plumbed in. Ive searched through the pictures but cant find my answer.
I no they attach to the plenum but where does the other end go? ATM mine is plumed into the presure reducing valve! is that correct?
it may b small but it purfectly formed
http://photobucket.com/albums/v340/1976_mi...roject%20turbo/
Kean
Member #: 341
aka T2clubby
South Staffs
The small connection on the dump valve needs to be connected to the engine side of the throttle, ie... the inlet manifold.
blown_imp
Member #: 598
Gaol
yeah the little tube into the top needs to have a vacuum line attached, this can be tapped into the inlet manifold.
J
On 5th of Sep, 2006 at 05:47pm mini13 said:
I reckon if his brains were gunpowder he couldn't blow his own hat off...
1976_mini
Member #: 259
grays, essex
cheers lads, i found most of the info needed when i opend my eyes and looked. lol. What ive just done is t-pieced it into the vacum pipe that comes out of the inlet manifold that goes to the crank case breather. But it still dont work! have i done something wrong or do you think my dump valve is nackered?
Kean
Member #: 341
aka T2clubby
South Staffs
No it really needs its own dedicated line to function properly mate.
1976_mini
Member #: 259
grays, essex
cheers mate, did sorta think afterwards wether the Air fliter would "nick" all the vacum or not. so you say i need to directly tap into the inlet manifold?
turbo hogster
Member #: 178
stowmaket suffolk
t piece of the vacuum pipe to the servo thats were i put mine
check that braided (fuel?) line your using isnt blocked, its not designed for vacuum so could be your problem...
as the other guys say, it should go to a nipple on the inlet manifold.
