Home > Help Needed / General Tech Chat > How much boost
velvitjester
Member #: 1351
I am new to this turbo mini business but not to tuning other cars,i was wondering if i get a metro turbo engine and gearbox rebuild the engine and fit an intercooler whats the maximum boost i can run and what bhp should i expect.I am aiming for the high hundreds or preferably 200.If this wont do it which im presuming it wont is avonbar the place to go and is their a specific kit or service i should be looking at .thanks
Dave
If by rebuild you mean "rebuild using standard spec parts" then you have no chance of achieving your power targets.
If by rebuild you mean "rebuild with carefully chosen (and expensive) performance parts, including all the induction, fuel, turbo etc parts, not forgetting a £1500 gearbox" then approaching 200bhp is perfectly possible, as a few of the guys on here can prove.
I suggest you do some reading of the forums, all the info is on here, but no-one will hand it to you on a plate, you need to do some reading and research.
have you driven a 200 brake mini???
mine is 142 and i think thats a damn quick car
velvitjester
Member #: 1351
cheers for the reply guys ,no i have a 450bhp skyline gts.so im quite used to fast cars.i meant rebuild with performance parts i was looking at the avonbar wesite for a performance rebuild kit but the most expensive one was 800 so it couldnt be what im looking for,il give them a shout tommorow.anyway thanks for the quick reply guys
blown_imp
Member #: 598
Gaol
a 200bhp mini will be about the same power to weight ratio as the skyline, should be very entertaining!
my limited knowlege of minis says that the mtero turbo engine was right on the limit as standard, so upgrades are essential to keep it all together. And the gerboxes are shoddy, chocolate gears *wink*
J
On 5th of Sep, 2006 at 05:47pm mini13 said:
I reckon if his brains were gunpowder he couldn't blow his own hat off...
No, I must argue with you there.
After extensive research and testing I have decided that in actual fact they are made of a special grey grade of sponge cake.
turbochargedstu
Member #: 908
gateshead
did someone mention sponge cake????
balls to the blower!!!
Straight cut gears are stronger as they have, an extra layer of icing. *wink*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Matty thats a cracking statment LOL!!!!
AlexF
Turbo Shed
Member #: 30
Epsom, Surrey
i went in a skyline with a claimed 650bhp and it felt slow compaired to the mini
the skyline may be faster (but i dont think so) but the 4x4 makes it sensible to drive. put all the power through the front wheels, restrict yourself to 165 wide tyres and you have a complete animal!!
blown_imp
Member #: 598
Gaol
also being surrounded by tinfoil, held up by rubber bands, and sitting only 6" off the floor, all combine to make the feel like its going twice as fast!
The imp was always like this, a 50mph blast down some country backroads was always an exciting experience. We would have to do about double the speed in my dads evo to get it to feel anything close to the imp!
J
