| Home > Help Needed / General Tech Chat > sensible mods | |||||||
298 Posts Member #: 1357 Senior Member telford,shropshire |
10th Nov, 2006 at 04:01:15pm
hi peeps, new to the turboing lark, just a couple of questions for the turbo gods.
'always keep a spare shot for a stray bird' |
10th Nov, 2006 at 04:24:12pm
The main head mod is to enlarge chambers to reduce compression. Do this and run some more boost with an intercooler and you should achieve an easy 120bhp.
10th Nov, 2006 at 05:14:14pm
thats helped alot also by rebuilding the gbox do you mean just to standard or to go for the close cut gears? 'always keep a spare shot for a stray bird' |
10th Nov, 2006 at 05:20:38pm
If you can afford straight cut gears then these are well worth it for strength, however if not it is still worth doing a standard rebuild, new bearings/shafts etc
10th Nov, 2006 at 07:14:45pm
on my build im just gonna use sc drops, as in my mind this the weakest link. "Turbo's make torque, and torque makes fun"
10th Nov, 2006 at 07:18:02pm
i like the idea of having the longer 1st with the sc/cr gears, should reduce wheel spin? My build thread..
10th Nov, 2006 at 09:07:13pm
Ive had mine for 2 years standard box, drops, diff, had no problems with any of them. I ran about 12psi of boost with an intercooler and a CR off 9.4:1.
10th Nov, 2006 at 11:43:55pm
agree with matty, std box can cope with 120bhp
397 Posts Member #: 694 Senior Member Shropshire |
11th Nov, 2006 at 10:31:02am
Look like I am in the same boat as you.
11th Nov, 2006 at 11:21:13am
Stig I would consider getting the cyl head to Benross for the chambers enlarging a shade. This will just drop the CR down a tad to make sure you stay out of detonation, don't need to go too far, just getting it down to 9:1 from 9.4:1 would do the trick.
11th Nov, 2006 at 01:24:48pm
Tom's right,
11th Nov, 2006 at 07:24:00pm
thanks alot guys thats a massive help, was thinking of modding the head 29mm exhaust and 36mm inlet, and if i rebuilt my spi gearbox ie replacing gears bearings and shafts could i use this for my engine or do i need a turbo box to begin with? 'always keep a spare shot for a stray bird' |
11th Nov, 2006 at 07:54:22pm
SPI gearbox rebuilt carefully will be fine for what you want.
14th Nov, 2006 at 07:05:03pm
All the above is true and good advice.
14th Nov, 2006 at 09:36:00pm
did a what??? "Turbo's make torque, and torque makes fun"
25 Posts Member #: 1331 Member |
18th Nov, 2006 at 01:54:06pm
if you've got an SPI wiring loom - you may want to swap it for a non-SPI loom
18th Nov, 2006 at 03:12:14pm
I would change the clutch too, to a pre verto setup. |
22nd Nov, 2006 at 10:08:27pm
im confused now guys, tom suggested that i could use my spi loom if i have a switched live to my coil.
11th Dec, 2006 at 06:31:47pm
hey guys, after many searches i still havent found the answer to this question. spi loom or change to a standard one??
11th Dec, 2006 at 06:39:57pm
Leave the ECU in if needs be to control the rev counter and water-temp (are you sure this is correct for the SPI)? And run a live to the dizzy and job's a goodun. On 17th Nov, 2014 Tom Fenton said:
11th Dec, 2006 at 06:46:21pm
see im unsure exactly what the ecu controls other than the injection system, if i left it in then, could i just add a bleed valve and dv to control boost? 'always keep a spare shot for a stray bird' |
11th Dec, 2006 at 06:52:13pm
rev is driven from the coil 12v, temp from the cylinder head 12v , not from ecu which have separate 5 v triggers flywheel and 5v water sensor |
11th Dec, 2006 at 07:02:39pm
so in theory, i could keep the ecu, run a live to the dizzy just disconnect injection connections and add bleed valve??? 'always keep a spare shot for a stray bird' |
11th Dec, 2006 at 07:47:38pm
yes |
11th Dec, 2006 at 07:49:22pm
thanks for clearing that up for me, long way off that stage yet but just wanted to clear it up. ta 'always keep a spare shot for a stray bird' |
(126 BHP on Mech Repairs rollers in Cheltenham and did a
