| Home > Help Needed / General Tech Chat > bleed valve problems | |||||||
![]() 341 Posts Member #: 259 Member grays, essex |
10th Nov, 2006 at 04:34:54pm
Hi guys, ive spent time reading through the search section )which is great alex), but cant quite find my answer.
it may b small but it purfectly formed
10th Nov, 2006 at 04:55:14pm
It sounds like someone has either fitted an uprated actuator or increased the preload on the standard actuator.
10th Nov, 2006 at 04:58:51pm
I agree with Tom, or could be a sticking wastegate, they can seize up. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
10th Nov, 2006 at 05:00:04pm
could also be an air leak, check all the pipes are nice and tight and have no splits Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
10th Nov, 2006 at 05:07:14pm
cheers tom/mat great advise as always, feebleuk, will check again but all the pipes/jubilee clips are new, cant rule out the obvious tho. it may b small but it purfectly formed
10th Nov, 2006 at 05:08:02pm
is there any way of checking wether the actuator is up rated or not? it may b small but it purfectly formed
10th Nov, 2006 at 05:10:04pm
What does it boost to without the bleed valve?
10th Nov, 2006 at 07:12:04pm
if you plumb the actuator directly to the plenum, then it should run at 4psi max if std.
10th Nov, 2006 at 07:41:03pm
actuator directly to the plenum? how do i do that? all i have is the one pipe from the actuator to the compressor housing.
10th Nov, 2006 at 07:43:22pm
I think we need a diagram here of how you have plumbed it in.
10th Nov, 2006 at 08:21:11pm
10th Nov, 2006 at 08:58:32pm
I think that the "compressor housing" and "outside world need" to be swapped over.
10th Nov, 2006 at 09:02:45pm
superb matty, will try in the mornin, when the neighbours may moan slightly less than they will do at this time of night. dont want to give them any more reason to report me! lol
