Home > Help Needed / General Tech Chat > Plenum chmaber
PaulM
Member #: 206
Just a thought, Could you fit a plenum chamber after the butterfly choke, on a turbo engine ?? *tired*
9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked
nutter driver
Member #: 47
Not very sunny swanage
dont think so...... why would you want to?
PaulM
Member #: 206
Just a thought re my three cylinder, it has a water 'cooled' inlet manifold , so is a little trick to mod
speedfreaq
Member #: 133
Jamaica
the water pipes to the inlet manifold would not be there to "cool" the intake but to actually heat it up when the car is cold :)
'I swear to use the Boost, The whole Boost'
'And nothing but the Boost..... So help me God'
PaulM
Member #: 206
Thats why 'cooled' is in inverted comma's, as during winter it will heat, during summer it keep it stable !
EFI turbo engines get best results from having a 'plenum' style inlet manifold. Just do a search for piccies of the YBB / YBD engines used in the sierra cosworths. These had a large volume plenum that was (at a guess) 3 litres in volume. Corky Bell states that the optimum is 1.7 times engine capacity.
So, yes. Cut and shut your manifold.
btw check out http://www.themininut.com and follow the links to his 'plenum fabrication' section. This is the right way to go about it...
PaulM
Member #: 206
Cheers dave, thanks for that
