Home > Help Needed / General Tech Chat > O/T cylinder wall thickness
Dangerous
Member #: 417
I have had a pit bike for a few months,In my quest for more power I am thinking of getting it bored from 54.5mm to 60mm(going from 124cc to 161cc)It's a aircooled 4 stroke engine similar to a honda 50/70/90 range
This will only leave 2mm thickness between the cylinder and the head bolts
Do you think it will be ok
i would not be concerned on the bores
but its the stud holes may pull out if the torque on them is high
give it a go bri
Edited by BENROSS on 14th Nov, 2006.
Dangerous
Member #: 417
I was thinking heat distortion,the 4 studs screw in at the crankcase,pass straight through the barrel and nuts on top of the head
give it a go you have only a barrel and gaskets and piston to lose
i bet you will be fine
