Home > Help Needed / General Tech Chat > flywheel
TURBO ME
Member #: 772
new york
can anything be done before installing new flywheel on crank
so it's not a pain upon removal?
did a search all i get is every idea about removal of flywheel
thanks people
check the 3/8" / M10 threads are chased cleanly, lap the flywheel on using super-fine lapping paste, clean crank and flywheel tapers with something like acetone that leaves no residue, torque flywheel up to factory specs, use loctite instead of a locktab (pre-verto), etc...
Basically - if you do all that, it'll come off with a puller and a good sharp blow. If it frets and welds onto the crank, it'll definately not come off easilly. :)
NOT the super strength lock tight
low strength vibration grade is just fine!
Ive always found putting the puller on, tensioning it up and getting a heat gun on it does the job! *wink*
Or if you haven't got a heat gun, put the puller on, tension it up, a leave it over night, come back in the morn and it'll be off!
Jackman
Member #: 984
Westhoughton, Bolton
Or if its like my old 998 it will fall off when you put the puller on it :)
Manchester Minis
At least you go the puller on it before it started to come loose! *blush*
its well worth getting a proper puller rather than the cheap draper one, the draper on's ok tig you get a stubborn flywheel.
Dangerous
Member #: 417
I got 6 puller threads in mine,and made a 6 bolt puller
