| Home > Help Needed / General Tech Chat > The metros fuel pump :( | |||||||
30th Apr, 2004 at 09:20:04pm
I cant find it! Where the hell is it! Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
30th Apr, 2004 at 09:38:27pm
ok great! Ill use that one then.
30th Apr, 2004 at 09:41:21pm
btw, im going to need 8mm piping arnt i? Im going to go to the plumbing shop tomorow and ask for some fuel resistant piping and see if they have any t pieces too, im going to give that idea a shot.
![]() 341 Posts Member #: 259 Member grays, essex |
2nd May, 2004 at 10:19:41am
go for the exhaust mate n if it dont fint then give it some slight persuasion! it may b small but it purfectly formed
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
3rd May, 2004 at 07:58:40pm
did u find the PUMP !!
TurboLessTosser |
5th May, 2004 at 01:21:04am
Ah! Look where the indent is for the spare wheel, towards the front of the car from that, there is a beam accross part of the chassis. ON TOP of that is a small beam, but if you get spanners (13mm) from the back you can lever them to undo the two bolts, i took off the mounting bracket AND the pump in one, so i have the rubber mounts already on to mount straight to the minisubframe (which i have already done, on the bottom beam on top, next to the hilo-suspension.)
