| Home > Help Needed / General Tech Chat > Sealing Zetec Jets | |||||||
15th Nov, 2006 at 10:20:19pm
Hopefully I'll be fitting my zetec jets on the weekend and having read & reread all the threads, and Phil's website I've still got one question:
17th Nov, 2006 at 01:12:52pm
i'm just going to put a small amout of thread type seal on the bore where it sits in the block, not too much mind,it wouldn't really matter if there was a small leakage as its inside the engine and there plenty oil pumping around.
17th Nov, 2006 at 04:16:25pm
Why not counterbore the hole a little and use a viton (so it will live with the oil and heat) o-ring? That will help keep the oil pressure up....
Edited by RogerM on 17th Nov, 2006. Every day is a school day ...........
19th Nov, 2006 at 03:31:52pm
Stupid question but what is a Viton o-ring and where can I find four of them? Isambard Kingdom Brunel said:
19th Nov, 2006 at 03:49:11pm
viton O ring is a regular o ring that handles more temperature |
19th Nov, 2006 at 04:59:52pm
Viton is the material the o-rings are made from. It has very good high temperature properties and is used in a lot of modern enigne instalations because it doesn't degrade in the manor that produces hydroflouric acid .... nasty stuff and the reason I won't touch anything out of a burnt out car!!!
19th Nov, 2006 at 05:46:34pm
These Viton ones,are they red in colour ?
19th Nov, 2006 at 05:50:03pm
Any colour you like mate, colour is just down to the pigment used.
19th Nov, 2006 at 07:07:44pm
Viton rubber does produce hydrofluoric acid when subjected to intense heat. |
19th Nov, 2006 at 07:35:59pm
It does you are quite right ...... but only if you get it hot enough to burn ..... in which case it is really not your main issue!!!
Edited by RogerM on 19th Nov, 2006. Every day is a school day ...........
