Home > Help Needed / General Tech Chat > bleed valve
nobbie
Member #: 162
right guys i know i have asked this question a million time before and i have looked at the how 2 section but i just cant get my head around it.
on the T3 turbo unit you have the pipe going from the actuator to the T piece on the turbo, then on the other side of the T piece you have a pipe that goes to the ECU, i have taken the ECU of and i will not be using it. do i simply just conect the bleed valve to that pipe, and i can adjust the boost from there on, or do i need to block that pipe off then conect the bleed valve to some ware else. if this is the case wat do i do with the other two conection on the bleed valve.
pleas can you help me.
wethepeople
Member #: 176
Pre-op Transvestite
Felixstowe, Suffolk
you can run it from there yes ... i think thats how ian does it.
(watch me be totally wrong here.. haha)
Yep, thats the way i do it, the other two connections just bleed to air.
Use the bottom one to connect up.
Works a treat
*smiley*
