| Home > General Chat > bloody headgasget. | |||||||
![]() 341 Posts Member #: 259 Member grays, essex |
18th Nov, 2006 at 05:09:47pm
about a month ago when i bought the car i changed the headgasget (amongst other things), as the condition of the engine was unknown. Except the running hot problem, she has been running fine. So with the help of a bleedvalve, actuator and needle/spring, i wound the boost up to 10psi (removing the ecu). I have been running 10psi for roughly a week now n last nite the headgasget blew on my way to work.
it may b small but it purfectly formed
18th Nov, 2006 at 05:14:45pm
I've seen 15psi a few times,just running a 27cc head(instead of 24?)
18th Nov, 2006 at 05:25:29pm
10 psi with standard CR ratio and no intercooler will........ blow the head gasket i can assure you ( detonation rapidly sets in):(
Edited by BENROSS on 18th Nov, 2006.
19th Nov, 2006 at 01:05:50pm
cheers guys, i do have an intercooler indoors, just havent got round to fitting it! will have to asap now!
19th Nov, 2006 at 01:21:45pm
Think your getting confused!! Benross is saying the cylinder head chambers need machining out to 28cc to give a compression ratio of 8.4-1 -MINI CLUBMAN 1380 TURBO- |
19th Nov, 2006 at 01:49:20pm
oh rite ok, thanks T3Tone. ive got a basic knowledge on turbo engines, never ever looked into machining tho! lol
19th Nov, 2006 at 02:21:48pm
Basic chamber size increasing is not too difficult.
19th Nov, 2006 at 02:22:23pm
Just another thought, you are running on a lead replacement with octane booster aren't you????? Every day is a school day ...........
19th Nov, 2006 at 03:54:38pm
my car runs on unleaded, but i use the 97RON. Do i still need octane booster? it may b small but it purfectly formed
19th Nov, 2006 at 04:45:30pm
That will be ok I think.
19th Nov, 2006 at 06:09:41pm
What gasket do you use?
On 19th of Nov, 2006 at 04:45pm RogerM said:
That will be ok I think. You've got hardened seats in the head then. Maybe I've only had old heads but I have never seen a factory turbo head with hardened seats. That is a good point actually, what seats are most people running on here? I seriously doubt it! |
19th Nov, 2006 at 07:31:13pm
yes the BK 450 is well up to the job
