| Home > Technical Chat > few brake Q: | |||||||
21st Nov, 2006 at 10:45:57pm
What brake setup do Miglias use?
21st Nov, 2006 at 11:15:11pm
On 21st of Nov, 2006 at 10:45pm wolfie said:
when looking at master cylinders i see that they are listed as 5/8 15/16 3/4 ect ect is there a table that converts to .625 .7 .750 ect ect Just use a calculator. Do 3 divide by 4 (3/4) and the answer is 0.75. 5 divide by 8 = 0.625 etc etc etc..........
21st Nov, 2006 at 11:20:09pm
21st Nov, 2006 at 11:31:52pm
Getting the master cylinder sizes right is a bit of a fiddle, needs some educated guesswork to get it right, on the 205 I have a 3/4 front and 7/8 rear master cylinders. However the caliper piston size areas are more evenly matched. On a Mini you are quite likely (esp with 4 pot calipers) to have approx 5 times the area at the front than the rear of the car.
22nd Nov, 2006 at 03:34:44am
.625" front (ap 4 pots) .750" rear (drums)
22nd Nov, 2006 at 09:12:47am
as for the miglia setup-
22nd Nov, 2006 at 09:13:41am
oh yeah and obviously a custom peddle box, or possibly could be standard off something, not sure. not something i've looked at too much! |
22nd Nov, 2006 at 08:49:55pm
it sometimews comes down to trying it and seeing if its too hard or not firm enough ,and then changing it for the better after finding out whats wrong , a smaller dia master would give a softer or more snsitive brake pedal , a larger dia would give a harder pedal .but untill you try it its sometimes hard to know whats best. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
22nd Nov, 2006 at 09:16:29pm
On 22nd of Nov, 2006 at 08:49pm robert said:
it sometimews comes down to trying it and seeing if its too hard or not firm enough ,and then changing it for the better after finding out whats wrong , a smaller dia master would give a softer or more snsitive brake pedal , a larger dia would give a harder pedal .but untill you try it its sometimes hard to know whats best. Yes I agree with robert completely, it usually comes down to some trial and error.
22nd Nov, 2006 at 10:27:36pm
Or use the formula that I found,bit mind blowing
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
23rd Nov, 2006 at 12:42:03pm
KAD do a reasonably priced twin cylinder pedal box, might be worth a look I've seen the future and tbh its Pie
23rd Nov, 2006 at 01:16:00pm
yeah think its 150ish and direct fit although not 100%.
23rd Nov, 2006 at 03:23:39pm
thats perfect Iain just what i wanted really, its what i wanted to try and make myself but to be honest it would have cost me that Crystal Sound Audio said:
23rd Nov, 2006 at 03:29:37pm
1012280 pedal box
23rd Nov, 2006 at 03:32:53pm
Adjustable bias pedal box unit
23rd Nov, 2006 at 05:45:02pm
added to the xmas list!! "Turbo's make torque, and torque makes fun"
23rd Nov, 2006 at 06:03:54pm
the cylinders are about 25quid each or summat, hardly worth batting an eyelid.
Edited by andeh on 23rd Nov, 2006. I've seen the future and tbh its Pie
23rd Nov, 2006 at 06:23:43pm
ooo that must have stung . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
23rd Nov, 2006 at 06:24:07pm
that must have been fun! look where the tree hit
24th Nov, 2006 at 07:40:54am
he was a lucky sob, but yeah hes ok I've seen the future and tbh its Pie
2nd Dec, 2013 at 01:15:40am
Piss poor wiring!
On 23rd Nov, 2006 andeh said:
Edited by Sprocket on 2nd Dec, 2013. On 26th Oct, 2004 TurboDave16v said:
