| Home > Help Needed / General Tech Chat > Blown Headgasket | |||||||
51 Posts Member #: 979 Advanced Member Auckland, New Zealand |
22nd Nov, 2006 at 11:18:41am
Hey all,
1975 MkIII Morris Mini 1300 Turbo, 100bhp...if only it could run long enough to drive it legally! |
22nd Nov, 2006 at 12:05:51pm
11 stud wont make a difference. i run up to 17psi and use 9 ARP studs |
22nd Nov, 2006 at 12:13:17pm
A bk450 headgasket is the best,which just so happens to be the standard one(I think)
22nd Nov, 2006 at 12:23:38pm
i always use a Payen AF470 head gasket and not had a problem in ages ( the problems i had were due to poor setup not the gasket) |
![]() 549 Posts Member #: 1347 Post Whore Croydon (South London) |
22nd Nov, 2006 at 12:38:08pm
I met a guy the other day who runs the overflow pipe from the rad onto his windscreen. So if his car dumps all the water out it fires into his face and he can stop sharpish.
Edited by AL on 22nd Nov, 2006. |
22nd Nov, 2006 at 01:50:15pm
Sounds like your head gasket mate!
Edited by matty on 22nd Nov, 2006. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
25th Nov, 2006 at 03:26:32am
I did the overflow pipe on the windscreen test and took it for a drive....yeah it spits out alot of water but only when i plant my foot on high boost.
25th Nov, 2006 at 05:36:26pm
your engine wont take even 10psi for that long , the intact temp will creap up to high levels unless you have a inlet temp sensor to keep an eye onit.
25th Nov, 2006 at 07:56:09pm
Wouldn't the throttle have to be wide open for the full half hour to have 10 psi, constantly, in the intake? |
26th Nov, 2006 at 09:15:58am
Turbo Hogster since you mentioned that i may have melted pistons i promtly went out in the garage and took the head off.
26th Nov, 2006 at 03:23:19pm
Well, either the valves are opening too far, too early/late, or they are staying open when they shouldn't be.
26th Nov, 2006 at 07:10:48pm
oh dear mate, take daves advice and go dor straight strip down.
