Home > General Chat > The Dangerous way of bleeding brakes !
Dangerous
Member #: 417
Just got my twin masters on front/back,couldn't find my easibleed even if I could it would prob have hard seals etc.
So I found approx 2 metres of see through pipe,stick it on the nipple other end in the mouth,suck as hard as you can whilst opening the nipple-watching all the air bubbles coming towards you.
Works a treat but try not to swallow*wink*
Hint...longer the pipe the better/safer
one tick i've used is a long length of tube run back to the master cyl just keep pumping till the bubbles are gone.
I always do the clutch like this, works a treat.
