Home > Wanted > suspension cones
pot_dan
Member #: 326
bradford, west yorks
need 2 suspension cones, really cant get mine off the rear trumpets at all, more miles on them the better*tongue* will consider all 4 if you really dont want to split 2/2 :)
thanks, Dan
They will come off, try harder!
A bolster chisel between trumpet and cone usually does the trick.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
I have had success with freezing them then running a little hot water over the joint .... usually fall straight into the sink ...
Carl
Member #: 95
liverpool-on-sea
lol the freezers probably the only place in our house that ive not got mini parts stored in, lol
If you dont want the Trumpets any more you do what i did and go the heavy heavy approach and smash the lip of the trumpet with a very large hammer!!!
Great Stress releif too!
pot_dan
Member #: 326
it was a while ago i read this, and today i finally got back out to the garage (after new year celebrations :) :) ) and for some reason i seem to remember you saying, put them in the oven and then run cold water over them and they will just fall off....
now mum wouldent let me put them in the oven, lol so i used a blow torch on the end just next to the rubber then poured cold water on then continued hammering, about 3 hits and it fell off!
tried a bolster chissel just before that with no luck tho.
altho i got the idea wrong, i got it sorted lol. that sides finished now on with the other side, witch is very very difficult becouse i cant get my wheel off...
thanks for the advice - and saving me money!*happy*
Dan
RogerM
Member #: 1217
Dan, firstly why can't you get the wheel off?
Nothing wrong with direct heat other than you don't want to damage the doughnuts. Glad to help.
pot_dan
Member #: 326
i have lost my locking wheel nut key, the front ones are off, but i have tried everything to get the rear ones off and failed. i know my mate will be able to at the mot station, witch will be the first place the car goes when its running so thats not a problem.. but untill then they are staying put, lol
Thanks Dan
