Home > General Chat > Changing wheel offset.
vrooom
Member #: 138
I got 5x10 mamba wheels, and i really like this wheel. But i would like to reduce offset to improve the handling of mini, as my wheel stick a inch out of my mini with standard arch fitted.
I wonder if it ok to grind the hub face part of the rim about 5 to 10 mm off, conisdering the the hub face of that rim is inch thick.
Would that be toooo dangerous in case of wheel fracture or safe to do so?
jay
slater
Member #: 1291
Suffolk / Birmingham
You can generally take a bit off but no alot. 5mm maybe but 10mm sounds a bit much
Mambas use sleeve bolts yes? if you take too much off then the bolts will bottom out on the hub face.
Kean
Member #: 341
aka T2clubby
South Staffs
I hope you are thinking about having this machined professionally and not attacking it with an angle grinder.........
Even so, I wouldnt fancy it
DO it,
I think that if you contact NASA, they could reduce the length of the sleeve nuts so they don't botom out on the face. If the guy is capable of machining the wheel in a lathe or similar, I think he both understands and is capable of getting the nuts to fit.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Be very careful with this as IIRC the mamba's are very close to the calipers anyway. If you machine much off you will get fouling between the wheel and calipers, V.bad.
This is of course assuming that you have disc brakes ..... if you have got drums and a turbo I am very scared ...... *wink*
good point!!
Nice one Carl!
Paul
On 30th of Nov, 2006 at 09:07pm fastcarl said:
DO it,
