| Home > General Chat > Minispares +40 piston rings | |||||||
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
1st Dec, 2006 at 01:17:07pm
Hi all,
1st Dec, 2006 at 02:07:14pm
I've a spare piston with rings and + 40 freshly bored block, but this is the rings coming with the pistons, not a ring pack, does it is in interest? |
1st Dec, 2006 at 02:10:41pm
Yes, could be one thats affected. How long have you had the piston ? Take the top ring off and try it in your +40 block. The undersize one i had came on a piston. 1 of the 4 was undersize. Edited by Mirage on 1st Dec, 2006. |
1st Dec, 2006 at 02:17:45pm
I'm just about to order some +40 Mega flattops. But this is worrying... On 13th Jul, 2012 Ben H said:
1st Dec, 2006 at 02:24:52pm
Surely a machine shop bores the block to the size of the pistons, then if the rings do not fit send them back.
1st Dec, 2006 at 02:49:03pm
Your right john, but its a bit worrying when 3 are right 1 is wrong and they are all marked on the rings as +40. I sent my affected ring back about 18 months ago!!!!!! My worry is that an undersize batch have been marked as +40 when they aint. I'm trying to sus out if current stock is undersize or not. These rings need to be checked in the bores before fitting back on the piston.
1st Dec, 2006 at 02:57:07pm
Well glad they are being helpful.
1st Dec, 2006 at 03:28:48pm
The rings are the same. I believe minispares made there rings the same as the omegas, as i believe there was a question mark over the availabuility of the omegas at the time.
1st Dec, 2006 at 04:54:21pm
i have +40 's and they seem to fit spot on
1st Dec, 2006 at 05:56:51pm
whats going on with this site today? axel is talking abou the size of his bum hole, wil and ben are talking about substitutes for toilet paper, and rich is talking about his dodgy ring!! heavens above
1st Dec, 2006 at 06:29:31pm
It's getting mighty itchy to i may add!!!!!.
14th Dec, 2006 at 06:16:42pm
Update.
14th Dec, 2006 at 06:29:10pm
Ring gap is not an issue with new rings as long as its above the minimum and not stupidly large you could get a bus through it.
Edited by Sprocket on 14th Dec, 2006. On 26th Oct, 2004 TurboDave16v said:
15th Dec, 2006 at 06:30:29am
forgotten to reply :o
15th Dec, 2006 at 07:27:59am
on this line, why on earth do minispares deliver the mega pistons with the rings on???! |
17th Dec, 2006 at 12:46:54pm
Mini sprocket what do you class as driving a bus through ? The ring gap should be within tolerance for the engine / ring etc. If its to large you are gonna get increased blow past and increased temperatures below the ring.
17th Dec, 2006 at 12:57:30pm
Oops i forgot to update you all.
Edited by Mirage on 17th Dec, 2006. |
17th Dec, 2006 at 06:09:12pm
On 17th of Dec, 2006 at 12:46pm Mirage said:
Mini sprocket what do you class as driving a bus through ? The ring gap should be within tolerance for the engine / ring etc. If its to large you are gonna get increased blow past and increased temperatures below the ring. I'd say ring gap becomes an issue when the manufacturer puts the wrong size on them. lol http://www.diagnosticengineers.org/Page%20B5-37.htm On 26th Oct, 2004 TurboDave16v said:
17th Dec, 2006 at 08:06:32pm
Good point ..... well made. Every day is a school day ...........
