| Home > Technical Chat > Piston & Ring Choice | |||||||
2nd Dec, 2006 at 10:47:15am
As some of you know I'm in the process of rebuilding my 1293 turbo and I'm faced with a dilemma as to the choice of pistons.
2nd Dec, 2006 at 11:18:33am
Accralite have a good rep with other engines so I can't imagine that they will be making rubbish for the A series, also Avonbar don't normally supply crap in my experienc with them .... never cheap but never crap! Problem for you is that the smallest dish they do is 14cc.
2nd Dec, 2006 at 11:20:50am
I seem to remember the JE pistons also do not have the standard compression height and so end up down the bore, and also do not take a standard gudgeon pin either.
2nd Dec, 2006 at 11:33:51am
Interesting ... Is the pin included?? If metal off the small end then that gives you an opertunity ... if metal on then that gives you a problem!! Every day is a school day ...........
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
2nd Dec, 2006 at 01:41:40pm
the pins are smaller than standard, and the compression height is 0.225" lower than standard pistons.
2nd Dec, 2006 at 01:53:18pm
Well dunno if this helps but TD is running the mega pistons IIRC and rates them,
2nd Dec, 2006 at 03:42:52pm
JF is also running mega pistons. These are VERY sturdy units, capable of a LOT of abuse. And they're cheap. And they're available seperately. And.....etc. On 17th Nov, 2014 Tom Fenton said:
2nd Dec, 2006 at 04:16:31pm
+40 mega here too since Dave recommanded them there is some time now ,they had to handle some bad treatment and never had an issu . some friends here are also using them without trouble (one at 1.3 bar (20 psi)) |
2nd Dec, 2006 at 04:25:01pm
I've got a set og Longman S Miglia rods used with JE pistons. They'v got a bronze bush in them. Easy. On 13th Jul, 2012 Ben H said:
6th Dec, 2006 at 10:03:13pm
I ideally want to got for 10cc pistons to keep the compression relatively high, my head has 26cc chambers and by my maths that gives a static CR of 8.9 (assuming 3cc for the head gasket & 0.75cc for the ring lan).
17th Dec, 2006 at 05:20:45pm
Sorry to bump up the thread, but I need to know if my idea of machining 1mm off the crowns is a sensible one or not, as my build is now getting delayed by my lack of pistons. Isambard Kingdom Brunel said:
17th Dec, 2006 at 05:22:50pm
I'd personally rather skim the head to achieve the reduction in volume rather than risk distorting a piston when you are trying to hold it in the chuck of a lathe to machine it down.
17th Dec, 2006 at 07:49:29pm
I picked the 13cc Mega pistons from Morspeed, Not much more expensive than the stock 6cc but morspeed turn them out to 13cc for you. I worked out that this gets you to compression ratio of 8.5 without any head mods (the crown height is slightly lower than Hepolite's)
Edited by Turbo Tel on 17th Dec, 2006. website:- http://www.terryhunt.co.uk
17th Dec, 2006 at 10:12:02pm
No I do not mean open out the chambers to increase volume.
17th Dec, 2006 at 10:30:25pm
Thanks Tom, I don't know why I didn't think of skimming the head. Isambard Kingdom Brunel said:
17th Dec, 2006 at 10:32:48pm
Yup
17th Dec, 2006 at 10:55:08pm
but then he was also going to deck the block flush with the pistons, so thee wouldnt be any gain.
17th Dec, 2006 at 10:56:56pm
On 17th of Dec, 2006 at 10:32pm Turbo Tel said:
Yup Any machining of the pistons would increase the volume, and thats the oppositeof what he is trying to achieve.. WRONG WRONG WRONG. Carefully read the thread previously! Rob was proposing to machine the TOPS of the pistons e.g. the squish band to SHORTEN the top of the piston, thus reducing the volume in the bowl. He would then deck the block to make the (now shorter) pistons sit flush to the deck again. Hence he would have DECREASED the volume of the dish in the piston, and INCREASED his CR, as required.
17th Dec, 2006 at 11:02:57pm
WRONG ...
17th Dec, 2006 at 11:08:53pm
Please carefully read what I wrote.
17th Dec, 2006 at 11:15:54pm
Nahh thats just a good left hook I'm still up!
17th Dec, 2006 at 11:21:53pm
On 6th of Dec, 2006 at 10:03pm British Open Classic said:
I'm toying over the Accralite but being 14cc it drops the CR a bit lower than I want (8.2 by my maths) so I was thinking about getting 1mm turned off the crown and then decking the block so the pistons come within a couple of thou of the top of the block, by my maths this should give a piston dish of 11cc and a CR of 8.8 :)
17th Dec, 2006 at 11:31:05pm
Thank you Tom, I'm glad someone understands what I'm on about.
17th Dec, 2006 at 11:34:57pm
Presuming the Accralites are standard height, they are 40 thou down, machine that 40 thou off the block and you reduce the volume above the piston by around 4cc
18th Dec, 2006 at 12:15:01am
OK I think I see what we are both on about now..
