Home > Help Needed / General Tech Chat > plugs
mattyking
Member #: 873
Thatcham, berkshire
what spark plugs are you guys running. as i have gone through a set now fairly quickly havnt had engine gone for to long a few months or so on and off. im using standard ones for metro turbo?
Ben H
Member #: 184
Melton Mowbray, Pie Country
Do a search, there are loads of threads and opinions and no definitive answer.
http://www.twin-turbo.co.uk
im using bpr7es ngk.
you need to run cooler plugs if you are upping the boost
a well chosen plug should have the ability to not foul up with carbon and deliver the spark with out running too cool, causing missfires and wet plugs
i have gone 2 grades cooler Champion N7y as opposed to N9Y and everthings fine
iam running 12 psi of boost at the moment through a good intercooler
hope this helps
Edited by BENROSS on 5th Dec, 2006.
Me to ! Never had any probs on these, 16-17psi or so.
My friend Mike uses the 6's and runs some "interesting" boost levels, strangely he's never had any problems around the 20psi mark. Though above this he did see some distortion of the metal electrode ! lol.
Phil. *smiley*
