Home > General Chat > sandblasting
the shed
Member #: 317
Does anyone no of a good place to get a mini shell sandblasted ???
thanks darrell
SON, WHATEVER FANCY SHIT YOU'VE GOT UNDER THAT BONNET, SEEN IT A MILLION TIMES
Dr. jinG
Member #: 368
Roseville, CA (USA)
I've read that sand blasting will warp the metal panels (most point to heat, but that's a shed-load; it's the work-hardening of the surface that warps things). Best is to soda blast. However, I had very good luck stripping mine with an abbrasive wheel from 3M: http://www.drjing.com/Mini/BLOG/BareShell.htm. For a few hours' work, you too can have a bare shell! :)
1967 Cooper 's' Turbo build @ www.drjing.com
depends where you are Darrell...
Acid dip is a favourite that a mate had done. no piece is left untouched then, the hardest bit would be making sure it gets coated with paint, not sure if the same place can dip in paint as well.
Ben H
Member #: 184
Melton Mowbray, Pie Country
If you get it acid dipped, it is a good plan to then get it electro galvenised. Obvoiusly this cost shed loads.
http://www.twin-turbo.co.uk
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
There is a place that advertises in PPC that can do the whole job, dip, galv' coat. I'll get a price for a shell and post it up here ... be patient though MEGA busy at work at the moment!
AV-R Technologies
Member #: 345
Guildford Surrey
If you still want to get in lightly blasted then i can recommend 'Essex & Herts shotblasting'.
http://www.avonbar.com
RogerM
Member #: 1217
Ok, the company is called surface processing ( www.surfaceprocessing.co.uk ) 01384 242010
I have rung them and for a Mini it would cost;
Stripping £575 + VAT (£675.63)
Etch primed and oven baked (spray coating so external only)
£350 + VAT (£411.25)
Electrophoretic (dipped) coating
£750 + VAT (£881.25)
The work they do is supposed to be brilliant and the electrophoretic coating should make the shell much more resistant to tin worm than anything else going BUT it's not cheap at £1556.88 for strip and coat!!!!!!!!!!
Back to the manual stripping for me .... anyway if it didn't rust I'd have no fun replacing panels and respraying would I!!!!
£600 was the price i'd heard for acid dipping. supposed to be the best way to get a shell clean though!
Certainly expensive with the coating. basically the price of half a new shell that comes already done.
Different if its something like a miglia shell though with cage etc fitted.
RogerM
Member #: 1217
Might be worth it for an early (59 / 60) mk1 shell but a bit out of my price range!!!
shane
Member #: 1246
Lowestoft, Suffolk.
Bead blasting is also an option, a little less harsh the grit blasting, as they use PET (plastic) regrind as the blasting medium.
Shane.
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Well does anyone know where i can get mine bead blasted in the north west. Cant find anywhere just shot blasting and i dont think my mini would survive it! LOL
modifiedminis
Member #: 768
Fixing my car....
Where i used to work (restoring 356's & early 911's) we used to get them bead blasted, never had any problems of panel distortion or anything like that
Carl
Member #: 95
liverpool-on-sea
i got the same quote, i didnt think it would be quite this deer, the problem i have is that my car is being built to be abused, and id hate to spend all that money on the shell for it to be rolled on the first tracjday!!!
Monster22
Member #: 39
Having mine done at the moment, alot less £ than has been quote above. He won't touch large panels as the media he uses is too tough.
Will post pictures and final cost hopefully with in 2 weeks.
The gentlemans a one man band and seems to do it as a hobby/business. He's near Wotton-under-edge.
Mark
andeh
Member #: 97
Near Daventry, midlands
i did a search on google in my local area for businesses and it came up trumps. About 10 places within 20miles of northampton and the closest was less than a 1/4 of a mile away from my house.
