Home > FAQ / Knowledge > Which BMW 16v cylinder heads? K1100 - K100 - K1200 - K1
Popeye
Member #: 262
Netherlands
Will a BMW K1 engine, also equiped with a 16v cilinderhead do the
job as a good source for parts? (throtle bodies, injectors, cams etc) I know the miniman uses a K1 cilinderhead, are they different form the 1100LT and 1100s ones?
I stumbled across one looking for a 1100LT or 1100RS engine, but these are very hard to find.
Cheers.
Bas
Moved to FAQ and added some words to help the search function *smiley*
Iain
Edited by iain on 8th Dec, 2006.
Op de bank beleef je geen avonturen
antman
Member #: 358
Snetterton, Norfolk
I think that the 16v k100 is the heda that Mini Sprocket used. I have a k1100lt for mine and it fits nicely. As far as i am aware they fit, and even use the same cams as the k1100 iirc.
johnK
Member #: 690
Norfolk
K100RS 16v from 1990
K1100LT
K1100RS
K1 16v (RS spec cams)- the garish coloured sporty one!
K1200 - avoid the LT from this engine size it has 235 deg cams not good!
all of these 16v heads have identical part numbers for the heads ,RS has 284 deg cams, LTs have 254 deg cams and less lift than the RS cams
K100 = 8v from mid 1985-1990 are the ones to use - exactly the same architecture as the 16v and they have 284 deg "16v RS" spec cams throughout the range.
Injectors are the same throughout the range as well - all 16v's have 34mm throttle bodies, 8v has 33mm throttle bodies
that about covers it!
If Carling made Mini engines
Popeye
Member #: 262
Netherlands
Great info John!
Maybe this posting shoud be moved to the FAQ section *wink*
martpaul
Member #: 668
newton aycliffe (near durham)
so which one would you source first? just wondering which is the better out of them heads?
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
john ,
I have a different info than your,
the 256 cam are std in all 1100(lt rs k1) engine
and 284 in the k100 ones (rs lt)
284 higher lift ones wouldn't be best for a lower rever, as they could push the rev band too high ,the 256 cam will give a power band more in the a seri possibility.
a four valver generally need 20° less than a two valves for the same power band (the 256 have a 276 cam comparison and a 284 compare with 304° cams)
jukka
Member #: 60
Forgotten more than most ever know
Is there are way to tell them apart, serial number perhaps ?
johnK
Member #: 690
Norfolk
Fab - yes mistake on my part - the K1100 LT/RS have numbers 1131464510/512 inl/exh and are quoted as 254°
the K1/K100rs 4v have numbers 1131461691/93 and are quoted as 284° - these are interchangeable with the K1100parts.
The K1200RS/GT have the same cams as the K1/K100RS.
apologies for the confusion.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
That is interesting.
Basically what we are saying is that for a turbo application you'd probably want a K1100 inlet cam and a K1/K100rs exhuast cam timed so that there is minimum overlap and the useful valve open period optimised.
Is there anything, short of a custom grind, that can be done to achieve something similar for the 8v???
Roger - maybe you could run more clearance between cam and the buckets? This will knock the duration down by a significant amount at the overlap; and you might not even notice any increase in noise over the drops / transmission / dump valve / turbo whistle anyways!!!
RogerM
Member #: 1217
LOL ......
I was actually refering to, as I'm sure your guessed, if there was any off the shelf cams for the 8v motor that could shorten the inlet duration .....
The K head is going in my car ..... noise won't be an issue in that as it will probalby do as many miles next year as it did this ZERO .. LOL
Edited by RogerM on 11th Dec, 2006.
fab
Member #: 100
Paris\' suburb
bimi heads are well balanced you don't need/want longer exhaust.
fab
Member #: 100
Paris\' suburb
Jukka,what's writen on yours? but sure it was from a k11
1100/256 are marked 461368 , sometime marking is difficult to read, mesure the lobe accross the lobe lift diameter and base diameter for 256 8mm lifts are 38/30
jukka
Member #: 60
Well you got me thinking earlier today and went down in the garage to check. I was actually going to post a question asking what my cams are. Fab has already answered my question: they are indeed 461398 cams.
RogerM
Member #: 1217
Fab, from the figures it does look like a balanced head flow wise but would it still not be better to keep overlap relatively low but exhaust duration relatively high? It's not so much wanting to have a longer exhaust as thinking there would be a benefit from reducing overlap which, if done on similar duration cams, would mean that the inlet would have to be opened very early.
This is common practice in other motors such as the VW 16V when using a turbo.
It sort of stands to reason in my mind as the exhaust efficiency is important to the overall performance and overlap is not too helpful as you could either end up throwing charge down the exhaust or having charge reversal and preventing full scavaging of the cylinder ....
I'm going to have to go and dig out my old text books from when I was at uni ..... been a long time since I have had to think about cams for forced induction SI engines.
