| Home > Help Needed / General Tech Chat > Could you point me in the general direcrtion of a suitable turbo? | |||||||
8th Dec, 2006 at 12:58:10am
I think my turbo's gone, it was a perfectly good unit with littel to no play and no smoke when i installed it and for the 2 months i have had the car on the road, until lthe last few days.
8th Dec, 2006 at 04:53:43am
20 psi is a bit high for at25 but it should have withstand with this longer, what about your oil line (coming from, and does it point down and above the oil level?
8th Dec, 2006 at 05:09:41am
I don't think you'll find a turbo that does what you want to be honest...
Edited by turbodave16v on 8th Dec, 2006. On 17th Nov, 2014 Tom Fenton said:
8th Dec, 2006 at 06:50:54pm
lol thought it may have been a bit of wishfull thinking. oil feed comes direct from the oil filter housing (filtered) i have noticed that on alot of aftermarket turbo kits that the oil feed line has a restrictor, mine does not, is this necesary? if so what size ID restricor should i try make up?
8th Dec, 2006 at 07:11:24pm
yes - plot the airflow at 2000, 2500, 3000, 3500rpm at 2/3 psi and you'll start to build the picture on where the boost will happen on the compressor....
8th Dec, 2006 at 07:14:34pm
when you write untill last days, does your turbo only smoking or have too much side/radial play?
8th Dec, 2006 at 07:20:31pm
On 8th of Dec, 2006 at 07:11pm TurboDave said:
There is a way of reducing the flow of the compressor however - effectivly bringing the whole map to the left - by drilling holes around the intake of the compressor... I've not tried it myself however - but know a guy who races at my local drag strip who does it to his turbo's if he experiences compressor surge. I'll speak to him more about it when i see him again next season... Im building a volvo lump right now with a great bigg ball bearing turbo (cant remember the specs off hand) but i did notice it has what looks like a slot that goes from half way alogn the smaller diameter part of the compressor wheel(in the compressor housing) to what i can only describe as the "plenum" of the compressor housing. this what your referring too? if so will dig up the turbo specs and see if theres a similar housing avaliable for a GT28 sereis units. know im askign alot but whats the script with turbine wheels? i get your point about the 3000rpm thing so how does turbine wheel choice affect where it makes boost? dont recall any of the online guides to reading turbo map's mentioning it.
8th Dec, 2006 at 07:23:11pm
On 8th of Dec, 2006 at 07:14pm fab said:
when you write untill last days, does your turbo only smoking or have too much side/radial play? as wrote a t25 will wistand with 20 psi more then 2 mounth, if it gone in this time, there is something wrong, what about your oil feed pressure?restriction is mainly used for bb turbos but can have benefitial if you have to much pressure (oil) about your pr/flow target look at the gt2259 map it should give what you need thankyou fab. not got around to pulling the turbo off the car yet, i stopped driving the car last night jsut before i made the post at some point after midnight, and had to get up at 7am ish to get to work, and am only jsut home, so simply not had the time. interestign thing is, the car drives great and makes boost fine, you only know theres a problem when you slow down and your own smoke overtakes you
Will look into that unit :) turbo 16v k-series 11.9@118.9 :)
10th Dec, 2006 at 02:24:53pm
little bit of an update, got soem free time to play with the car today, the turbo how has tonnes of play in it, to the point where the wheel can easily touch the housing with the bearings dry :( its fucked. on teh bright side the engine appears to be in good health!
