Home > Technical Chat > exhaust elbow
I recently won an ebay auction for an exhaust elbow and having recieved it it appears to have been modified. (poorly)
the face that bolts to the turbine housing has been bored out 5mm wider then the turbo outlet.
will I loose power as a result of the 2.5mm misalignment each side running 10psi boost?
If need be I've got an un-molested one some where, which you can have.
:EDIT: I hope that reads better now.
Edited by Rob H on 10th Dec, 2006.
thanks, that was what I was thinking.
sorry just read that wrong, i thought you said i'd get an unmolested one rather then you've got an unmolested one
wtf is going on here.
ps, I don't think the mods will affect it that much if at all.
please post some pics up
I'll do that at the weekend when I get home from uni.
