Home > Help Needed / General Tech Chat > Flywheel bolts
slater
Member #: 1291
Suffolk / Birmingham
Can i use a verto flywheel bolt and 'key washer' (not sure what they are called tbh) on a pre verto clutch? i cant see any problem but i wanna check theres nothing im missing
You can use the bolt - and I guess you 'could' use the stepped washer aswell? You will need to use loctite however :)
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Certainly can, no problem.
I usually replace all that stuff at a rebuild however as I have had them come loose ... not nice, especially on the M25 in morning rush hour!!!
Loctite is a good option, just need thread lock, don't go too heavy duty as you'll struggle to get it off next time.
Dangerous
Member #: 417
I angle ground the spotted on lock tab off the verto bolt and used that with the preverto lock tab and preverto keyed washer
Reason I had a socket that fitted the verto one
slater
Member #: 1291
Cheers guys, il stick some 222 screwlock on it to be safe
pickmeup
Member #: 1200
does anyone know what spec the material should be of the stepped locating washer as I ordered one from moss over 2 weeks ago and still not got it!
The one i removed from the car was damaged after only 1500 miles, does anyone produce a high spec item?
minispares do an upgraded washer, and bolt, 24t rings a bell...?
