| Home > Technical Chat > Max psi | |||||||
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
10th Dec, 2006 at 09:50:44pm
Whats the highest PSI any1 has seen a mini running at? Back once again like a renegade master |
10th Dec, 2006 at 09:51:28pm
Highest ive heard is 28 and that was from my mates clubby. Back once again like a renegade master |
10th Dec, 2006 at 10:25:14pm
but was it effciently running 28psi? |
10th Dec, 2006 at 10:30:46pm
You can keep winding the boost up but at some point you meet the law of deminishing returns, ie. all the extra boost just goes to heat the charge and thus lower charge desity thus reducing the combustion efficiency.
Edited by RogerM on 11th Dec, 2006. Every day is a school day ...........
3596 Posts Member #: 655 Post Whore Northern Ireland |
11th Dec, 2006 at 12:26:16am
I ran and abused mine daily at 1.5 bar, CR was around 7.5:1
Edited by stevieturbo on 11th Dec, 2006. 9.85 @ 145mph
11th Dec, 2006 at 01:15:15am
On 11th of Dec, 2006 at 12:26am stevieturbo said:
In fact, its rather pointless on its own. Amen to THAT!!!! Big numbers impress chavs - the types of chavs that have no idea if a 12 sec 1/4 is good or bad... On 17th Nov, 2014 Tom Fenton said:
11th Dec, 2006 at 12:02:32pm
And the sort that think a pod filter and associated sticker adds about 30-40bhp. On 7th Nov, 2008 Nic said:
11th Dec, 2006 at 03:56:08pm
the name of the game is to generate as much HP through as little boost as possible
11th Dec, 2006 at 05:35:36pm
As the guys said, get everything as efficient as possible first then turn the boost up.
11th Dec, 2006 at 05:36:32pm
On 11th of Dec, 2006 at 12:02pm Jay#2 said:
And the sort that think a pod filter and associated sticker adds about 30-40bhp. Surely not .... the adverts claim at least 10% and we all know a 1L Saxo comes out of the factory with 200BHP!!!! Every day is a school day ...........
![]() 725 Posts Member #: 177 Avon Park 2006 Class D Winner Woburn Sands |
11th Dec, 2006 at 05:42:05pm
I've run just over 30 psi, but can't get a clutch to cope with that much boost 16V project underway |
11th Dec, 2006 at 11:36:27pm
Yeah i know that the engine needs to be efficient. I was just wondering how high some nutter had cranked up the boost without his rings frying of head gasket making funny noises Back once again like a renegade master |
12th Dec, 2006 at 08:44:36am
I once pumped my left rear tyre up to 42psi! How cool am i! |
12th Dec, 2006 at 09:39:59am
Mate had a huge Holset in his Mini. Really a pile of crap honestly. CR was reduced by machining the piston tops so that the pistons were 4 mm down in the bore at TDC. Then there was a locked dizzy to supply something like 20 degrees advance. All in all, the engine did not see any boost below 4000 rpm. Any std 1275 would blow the doors off ... until it came on boost. In an instant it hit past 1,5 bar. We then backed the wastegate settings to keep it around 1 bar because my mate had no idea what the engine spec was. I would imagine that judging the amount we had to adjust the wastegate we would have hit 2 bar easily. Absolute PITA despite the boost setting.
12th Dec, 2006 at 06:39:21pm
On 12th of Dec, 2006 at 09:39am jukka said:
Mate had a huge Holset in his Mini. Really a pile of crap honestly. CR was reduced by machining the piston tops so that the pistons were 4 mm down in the bore at TDC. Then there was a locked dizzy to supply something like 20 degrees advance. All in all, the engine did not see any boost below 4000 rpm. Any std 1275 would blow the doors off ... until it came on boost. In an instant it hit past 1,5 bar. We then backed the wastegate settings to keep it around 1 bar because my mate had no idea what the engine spec was. I would imagine that judging the amount we had to adjust the wastegate we would have hit 2 bar easily. Absolute PITA despite the boost setting. I have accidentally hit past 1,5 bar with mine (interesting to say the least) but kept it at 1 bar for years. pmsl, sounds like mine
Except I took 6mm off the top, and welded dizzy at around 24-28deg. My Cossie compressored T3 built boost rapidly around 36-4000rpm to 1.5bar then flew. I probably did see more at times, but that was steady readings. That said, I did try for more, and it didnt seem to want to make much more than that, so just left it there. 9.85 @ 145mph
12th Dec, 2006 at 07:41:42pm
On 11th of Dec, 2006 at 03:56pm BENROSS said:
the name of the game is to generate as much HP through as little boost as possible you do of course mean torque, not HP.. carl |
12th Dec, 2006 at 07:45:52pm
the name of the game is to generate as much HP through as little boost as possible you do of course mean torque, not HP.. carl And you of course mean culy-wurlies, not bananas.. On 17th Nov, 2014 Tom Fenton said:
12th Dec, 2006 at 08:17:13pm
f--k off.lol |
12th Dec, 2006 at 11:19:23pm
yes dave, carl, ................ Torque!
5th Mar, 2007 at 07:23:20pm
Cricky ..... what is the difference in charge temps to be causing that? Or is the turbine backing up the exhaust preventing charge scavenging?
