| Home > Technical Chat > jet needle area? | |||||||
11th Dec, 2006 at 06:22:00am
Does a change in jet area (hole) by about 30% (0.90 to about 1.2) would change all the fuelling curve by a linear 30 % with the same needle or does it will have an exponential increase as the jet is unmasking the hole?
11th Dec, 2006 at 08:52:19am
As fuel pressure rises it will indeed be non linear. On 13th Jul, 2012 Ben H said:
![]() 6753 Posts Member #: 828 Post Whore uranus |
11th Dec, 2006 at 04:54:52pm
good q fab , i think that the needle profile remaining the same ,and the hole getting bigger ,would mean the ratio of needle to hole would change as it got further and further out of the hole eg ,as rpm rose .so if we had a 3 square inch hole ,and a 2.5 square inch area needle in it that would give .5 square inches at tickover ,and then a 2 square inch needle at rpm ,that would give a 1 square inch hole for fuel , but then take the 3 square inch hole ,and make it 3.5 square incch ,then at tickover it'd be 1 square inch ,but at rpm it would be 1.5 square inch ...
11th Dec, 2006 at 05:26:11pm
also, back to basic maths, a circles area increases exponentially with its diameter, so adding an extra 30% to its diameter will give more than 30% will give more than 30% increase in area... "Turbo's make torque, and torque makes fun"
11th Dec, 2006 at 05:27:21pm
11th Dec, 2006 at 06:22:14pm
3596 Posts Member #: 655 Post Whore Northern Ireland |
11th Dec, 2006 at 07:12:33pm
If you are struggling for fuel....fit a 0.125" needle into the carb, and drill/ream the jet out to 0.125"
11th Dec, 2006 at 07:41:54pm
thanks but not struggling with fuell, just a weigher one,
