| Home > Technical Chat > Crankshaft taper | |||||||
13th Dec, 2006 at 06:23:19pm
Does anyone know where I could get the taper of a crankshaft reground by a few thou?
I seriously doubt it! |
13th Dec, 2006 at 06:27:41pm
show me some pics,
13th Dec, 2006 at 07:06:44pm
Eh, I dont know how to, nor do I have a camera.
On 13th of Dec, 2006 at 06:27pm fastcarl said:
show me some pics, carl I seriously doubt it! |
13th Dec, 2006 at 07:12:38pm
if you dont grind lots of you can still use a std flywheel, just put it in the lathe and remove a little bit fomr the backside where it will interfere with the primary otherwise. and just put the crank in the lathe and remove a little bit on the nose so you have half a mm betweeen the edge of the flywheel and the end of the taper |
13th Dec, 2006 at 07:17:09pm
This was the idea, but the flywheel material that was left on the crank formed a hard spot, so when I turned it it left a slight bump so it does need a grind.
On 13th of Dec, 2006 at 07:12pm miniminor63 said:
if you dont grind lots of you can still use a std flywheel, just put it in the lathe and remove a little bit fomr the backside where it will interfere with the primary otherwise. and just put the crank in the lathe and remove a little bit on the nose so you have half a mm betweeen the edge of the flywheel and the end of the taper I seriously doubt it! |
13th Dec, 2006 at 07:24:10pm
Paul, User Dangerous on here will probably fix it for a few beer tokens - he's done metal spraying and grinding for guys on here in the past - And i know he asked me what the crank taper angle was around 2 months ago - presumably for a similar job? On 17th Nov, 2014 Tom Fenton said:
13th Dec, 2006 at 07:27:22pm
Nice one Dave, I'll contact him, Cheers.
13th Dec, 2006 at 08:05:15pm
there you go, problem almost solved,lol.
13th Dec, 2006 at 08:38:35pm
I can regrind it one quiet weekend in my dinnerbreak !
265 Posts Member #: 368 Senior Member Roseville, CA (USA) |
15th Dec, 2006 at 09:05:24pm
Metal spraying? Meaning depositing metal, or something else? I don't think I've heard of that one before.
On 13th of Dec, 2006 at 07:24pm TurboDave said:
Paul, User Dangerous on here will probably fix it for a few beer tokens - he's done metal spraying and grinding for guys on here in the past - And i know he asked me what the crank taper angle was around 2 months ago - presumably for a similar job? **************************************
15th Dec, 2006 at 09:34:02pm
Yes, depsoting metal. Google is your friend my friend :) On 17th Nov, 2014 Tom Fenton said:
15th Dec, 2006 at 10:10:04pm
On 15th of Dec, 2006 at 09:05pm Dr. jinG said:
Metal spraying? Meaning depositing metal, or something else? I don't think I've heard of that one before. http://www.homestead.com/aflame/files/Dgun.doc
