| Home > General Chat > Remote - Rod | |||||||
15th Dec, 2006 at 07:17:57pm
Hi, this has probably been asked before but couldn’t find it on a search, does anyone know if I can take the gear set from a remote type gear box and put them in rod type? Do I need any additions from the set in the remote type?
15th Dec, 2006 at 07:21:51pm
Vegards your man to answer this...........
15th Dec, 2006 at 07:41:02pm
15th Dec, 2006 at 07:47:05pm
cheers chaps, i would need to swap them into an A+ so i might be out of luck then.
16th Dec, 2006 at 11:32:51am
Yes you can :) As long as they are both A and 4sync, the only difference is the reverse gear.
16th Dec, 2006 at 05:21:20pm
so just to clarify,
16th Dec, 2006 at 06:11:27pm
A in an A+ is easy. Both layshaft holes are similar, it's the shaft that's different.
16th Dec, 2006 at 10:15:11pm
just sorted this out over PM, big thanks goes out to Vegard! the gearbox guru! Edited by MarkGTT on 16th Dec, 2006. |
