| Home > Help Needed / General Tech Chat > g g g gaskets | |||||||
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
5th May, 2004 at 09:51:41pm
An old trick but a good risky probably crappy and worrying one but her goes TurboLessTosser |
5th May, 2004 at 09:56:41pm
a guy in brewsters pub the other night told me to do this! I told him hes talking rubbish. Have i made an arse of myself!
5th May, 2004 at 10:00:35pm
Turbo heads and std heads will most likely have the same chamber volume, hence compression. The important part about the turbo head is the good quality valves, better coolning distribution in the casting etc.
5th May, 2004 at 10:01:15pm
I thought the metro turbo head was 9.4:1 which is the same as most other metro 1300's
TurboLessTosser |
5th May, 2004 at 10:08:39pm
2 head gaskets is a no no..it is very easy to scoop out the head yourself, i've done it with an electric drill before.
5th May, 2004 at 10:11:51pm
giallofly
TurboLessTosser |
5th May, 2004 at 10:12:17pm
Turbo head chamber volume is the same as the other Metros, 21.4cc or so.
![]() 2641 Posts Member #: 19 Post Whore newcastle |
5th May, 2004 at 10:14:06pm
turbo heads also have larger 3 groove collets on , as i know as i have loads of larger ones and can`t find any smaller ones for my head. Everyone knows that instructions only have to be read if the thing doesn't work....
5th May, 2004 at 10:16:39pm
Enlarging the chambers is not to difficult, this is what i've used in the past for head mods -
5th May, 2004 at 10:21:42pm
phil any pics of your head?? Everyone knows that instructions only have to be read if the thing doesn't work....
5th May, 2004 at 10:22:32pm
Head off, strip it down, get a couple of old valves put the old valves in to protect the valve seats and start grinding into the chamber. smooth out the beak shape or even loose it totally. Before grinding use he old head gasket as a template so you don't grind too far into the head face onto where the firering sits.
6th May, 2004 at 12:29:10am
I can get syringes free too if anyone needs them, i work for Cartridge World part time, we throw them all away after filling a certain number of cartridges would be better to suggest rather than throwing them away. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
969 Posts Member #: 47 Post Whore Not very sunny swanage |
6th May, 2004 at 07:48:09pm
ive got two head gaskets on mine, and its absolutely fine. however it has only been running for about two hours and not been driven anywhere yet!
And on the 7th day........... God created turbochargers! |
