Home > Wanted > 1275 Engine Block
pickmeup
Member #: 1200
Hi all
Im needing a bare engine block or short engine , A or A+ 1275 or above for plugging to build my bmw twin cam engine!
Can come and collect as long as its not far from bristol
Gaz
i have an A series block.in leeds.
carl
pickmeup
Member #: 1200
little bit far away , if my girlfriend was still living there it wouldnt be a problem!
cheers tho carl!
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
I might have a block spare but it depends on what you want to do with it .... hate to let you take something that you couldn't use.
That's not the old Cooper block you're referring to by chance?
RogerM
Member #: 1217
I have several engines kicking around, some I need, some I want to keep others could go to a good home...
The cooper block probably isn't what he's looking for as it's linered and in need of some new ones ... although I'm probably not going to use it .....
I have a couple of 1275 blocks that need a rebore but aren't linered ... some are, shall we say, well weathered though.....
pickmeup
Member #: 1200
i need to have a chat with you roger! im sure you have something useable?
RogerM
Member #: 1217
There are a couple of 1380 lumps with crank rods and pistons too if it's for the NA K headed beast your thinking about !!!
pickmeup
Member #: 1200
yeah its for the twin cam K monster! i fancy building two one with a std 1275 and a monster 1380, that way i can see if they are good for everyday as well as the track!
RogerM
Member #: 1217
You have my number ....
