| Home > 998cc > 998 Supercharger | |||||||
16th Dec, 2006 at 11:26:54pm
As my Midget is finish and the 1293 T2 engine for the British Open is coming together quite nicely, I've decided it's time to look for a new project.
16th Dec, 2006 at 11:45:18pm
i havent a clue about superchargers, but a close friend is currently using a M42 (no idea why) to supercharge his R1 engined kitcar.
223 Posts Member #: 598 Senior Member Gaol |
17th Dec, 2006 at 12:29:03am
sounds like an ace project, this is my supercharger calculator -
On 5th of Sep, 2006 at 05:47pm mini13 said:
I reckon if his brains were gunpowder he couldn't blow his own hat off... |
17th Dec, 2006 at 02:05:03am
try this for the supercharger calculator -
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
17th Dec, 2006 at 08:34:27am
im in the middle of building a friend a supercharged 998, front mounted m45 with an intercooler and a blow through carb. Another chap on here has done the same thing with a 1380. Definatly the way to go IMO.
17th Dec, 2006 at 08:37:08am
J, Your excell file still wont download. I've seen the future and tbh its Pie
17th Dec, 2006 at 10:15:40am
I dont think you can do a blow-through setup with a positive displacement supercharger. It will all go bang.
17th Dec, 2006 at 11:14:54am
The efficicency of the M45 isnt too bad, They can be ported and the noise reduction ports sealed to increase the efficiency.
17th Dec, 2006 at 11:49:52am
There are obviously many maps!
Edited by Paul S on 17th Dec, 2006. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
17th Dec, 2006 at 01:38:15pm
This is a good site for supercharger stuff.
17th Dec, 2006 at 01:57:54pm
Exactly, you need a specific supercharger bypass, which is very different to a turbo dump valve -
17th Dec, 2006 at 02:00:03pm
It would appear that the calculator isnt availble to download if im not logged in. Can it be saved on this site? Its ony about 20kb in an excel file.
17th Dec, 2006 at 02:09:34pm
Glad to see you have it covered with that wastegate.
17th Dec, 2006 at 02:12:19pm
Blown_imp ... if not I'll host it .. loads of space and nothign to fill it ... LOL Every day is a school day ...........
17th Dec, 2006 at 02:27:28pm
Lets try this -
Edited by blown_imp on 17th Dec, 2006. On 5th of Sep, 2006 at 05:47pm mini13 said:
17th Dec, 2006 at 04:14:59pm
On 17th of Dec, 2006 at 01:57pm blown_imp said:
Throttling the inlet of a supercharger drastically reduces its efficiency, overheating any air that gets through and heat soaking your intercooler. Putting the throttle after the blower means its always working at it best, reducing inlet temperatures. Cheers J gosh j , i would in an amicable way totally dissagree with that ( with absolutley no evidence to support my point of view!!lol) yes throttling the sc would reduce its efficiency , but if hardly any air is going through it ,then it cant compress so cant build heat ? i imagined it would run in a partial vacuum ,and possibly get cooler not hotter in that state ,putting the throttle after the rootes type blower ,would i feel make it a major job to stop big damage to the rotors when you slam the throttle shut , no matter what bleed mechanism you have on it ,.what do you think ? bear in mind my two stage stuff is turbo's not mixed media ,so this is not the voice of practical experience ,i can see it all working up to a point ,with a v big fast reacting bleed down ,but in time i think distortion of the rotors ,and casing would accrue .and if a throttle on the inlet side does the job as well ,without the drawbacks that would be best . great subject to hypothesise about regards robert. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17th Dec, 2006 at 04:17:03pm
On 17th of Dec, 2006 at 10:15am Axel said:
Needs a secret cam of course ![]() blooody funny axel you do make me laugh .thanks . ![]()
17th Dec, 2006 at 04:19:09pm
whoops , iv just realizeed , the bini cooper s has the throttle after the blower , so does my sisters db7 ,doh , so sound like im talking drivel , !!!! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17th Dec, 2006 at 04:31:04pm
There shouldent be too much of a problem with distortion as the volume of the inlet system after the throttles is far smaller than the volume prior. When the throttles close the area after is evacuated very quickly pulling the valve open, the area prior wont have much time to 'pump up' in consideration of the time and volume of air being moved.
17th Dec, 2006 at 04:32:42pm
On 17th of Dec, 2006 at 04:19pm robert said:
whoops , iv just realizeed , the bini cooper s has the throttle after the blower , so does my sisters db7 ,doh , so sound like im talking drivel , !!!! I think they use some sort of actuated recirculation device. On the attached picture, the bit underneath houses a valve, I think. Edited by Paul S on 17th Dec, 2006. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
17th Dec, 2006 at 04:43:34pm
Needs a secret cam of course ![]() blooody funny axel you do make me laugh .thanks . ![]() ![]() Well, we can all play silly buggers
17th Dec, 2006 at 05:17:11pm
Thanks for all the input so far, its definitely me a fair bit to think about, and those maps make by little brain hurt. Isambard Kingdom Brunel said:
17th Dec, 2006 at 08:07:32pm
Right here is my supercharger calculator, really really!
13th Jan, 2007 at 02:28:54pm
Rob,
13th Jan, 2007 at 07:52:57pm
I've given this a fair bit of though and I'm probably going to go down the 998 turbo route instead, that way I can have two half build Turbo Minis instead of one! Isambard Kingdom Brunel said:
