Home > Wanted > valves
fuiafonte
Member #: 695
PORTUGAL-VISEU
i want 36 inlet and 32 exaust valves for mi turbo head i´am from portugal if someone could help please help me....
minispare race valves are the best
they do a 35.6mm inlets and a
31mm exhaust
click on the link and this compay delivers worldwide
http://minispares.com/
Fuiafonte: No, you don't t want such big valves. Fist of all, there so room for them unless you offset them. Second of all, the seats WILL crack.
35,6 and 31mm is what you need unless you've got too big valve seats from earlier.
fuiafonte
Member #: 695
PORTUGAL-VISEU
thank you,i have a vmax scart pistons(low ccr),mrspd stage 2 t2 turbo cam a garret t2 turbo 1.5 full roller rockers... and i want a 140 bhp motor what do you think about 32,36 valves.its too big for wath i want?
miniminor63
Member #: 672
The oversills police
Oslo, Norway
it is too big period if you do not want cracks to occur. you will easily be able to get 140 hp with the valves suggested by Vegard above.
Or - you'll get better results with 35.6/29mm standard A+ valves and spending your money on a correctly-specced turbocharger...
fuiafonte
Member #: 695
PORTUGAL-VISEU
tank you and.with this lot of things do you think i am able to have 140 hp motor...or i need more?
140hp isn't to hard to achieve, a relativley basic spec engine will give this, and more, providing it's well built and set up correctly.
Lightly modified head with 36/29 valves, Phase 2 cam, decent intercooler and 10-12psi should see you there.
Phil. :)
fuiafonte
Member #: 695
PORTUGAL-VISEU
thank you phill...
