| Home > Help Needed / General Tech Chat > Help! Dipstick leaking! | |||||||
17th Dec, 2006 at 03:12:00pm
Please help me, It's been a week now since my dipstick has been pumping copious amounts of oil onto my shiney engine bay!
In the 13's at last!.. Just |
17th Dec, 2006 at 03:57:35pm
sounds like its breathing very heavy.
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
17th Dec, 2006 at 04:07:19pm
ye make sure the rubber o ring is on the dipstick i had same trouble when it wasnt on there but it also sounds like heavy breathing "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
17th Dec, 2006 at 04:29:31pm
or pop a spring on it to keep it down, i did that and ive no longer had a problem |
17th Dec, 2006 at 04:54:14pm
I had to use a spring to keep my dipstick in clean and dry.. 9.85 @ 145mph
17th Dec, 2006 at 04:57:51pm
the spring method is a classic mod, it works well! My build thread..
17th Dec, 2006 at 08:04:33pm
Should I worry about the pressure building up? I have been told that this is due to leaking engine wear (piston rings, bores etc etc) is this true? am I looking at needing a rebuild in the near future? In the 13's at last!.. Just |
274 Posts Member #: 1174 Senior Member Sunny Southern California, USA |
17th Dec, 2006 at 08:33:47pm
Is your oil pressure unusually high? You might want to install one of those adjustable oil pressure relief valve. Adding a spring to the dipstick may stop the leak. But it isn't solving the actual problem. 61 Austin Seven; building a 1275 'over the clutch' turbo, R5 T2'd, custom intercooled, megajolt electrified, canyon carver
17th Dec, 2006 at 08:53:19pm
my thoughts exactly! Oil pressure is as usual, 60 when cold 40 when warm.
17th Dec, 2006 at 09:02:48pm
blowby is the only solution I can see then? |
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
17th Dec, 2006 at 09:04:41pm
I cant see the pressure having any thing to do with it its breathing heavy that causes this or just a dicky dipstick.
17th Dec, 2006 at 09:58:56pm
Pull the oil filler cap off and see if there is any excess crank case pressure. If it's breathing heavy enough to blow out the dip stick it should be pretty obvious. Edited by Jay#2 on 17th Dec, 2006. On 7th Nov, 2008 Nic said:
17th Dec, 2006 at 10:02:11pm
Dipstick not connected to HP oil circuit ... how could oil pressure be the cause (i.e. that created by the oil pump) .... can't see this myself. Edited by RogerM on 20th Dec, 2006. Every day is a school day ...........
18th Dec, 2006 at 07:20:27am
mine done that found out them kn typr oil beathers were patially blocked, remove the oil breather filters then see if it leaks, another as well is look in the rocker cover whilst running, i had oil spurting up pushrod holes. ive found them type of filters are a waist of time. always looking for them bigger bunches of bannanas |
20th Dec, 2006 at 06:44:25pm
While the gearbox itself isn't pressurized (that I am aware of), if the breathers are clogged, or something else causes pressures inside the motor to increase above normal, pressure builds inside the motor. The air and sometimes oil will then escape at the point of least resistence. Sometimes it's the dipstick tube.
On 17th of Dec, 2006 at 10:02pm RogerM said:
Dipstick not connected to HPoil circuit ... how could oil pressure be the cause .... can't see this myself. Edited by Lance Link on 21st Dec, 2006. 61 Austin Seven; building a 1275 'over the clutch' turbo, R5 T2'd, custom intercooled, megajolt electrified, canyon carver
