Home > Help Needed / General Tech Chat > Wheres best to connect a wire to flash the indicators?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
ive just fitted remote central locking to my mini, the last bit to do is to connect a wire that flashes the front indicators when you press the button.
Wheres the best place to join the wire? Should i run it to join by the flasher relay under the bonnet? or how about the connector under the indicator stalks? I was wondering if the relay would cause problems if i did that.
thankyou!!!
Dangerous
Member #: 417
It will have to go on the hazzard relay to flash both sides
You'll need a diode bridge otherwise you will cross connect both sides and bugger up your indicators.
jamesfawcett
Member #: 218
cool ok will it flash front and back?
jamesfawcett
Member #: 218
cool yeah it came with a diode to stop theives starting the car through the indicators too lol!!!
Dangerous
Member #: 417
Yeah my mate did that with a car alarm,it was meant to flash the side lights but he wired it up to the indicators..................Trouble is when you go left or right they all come on*blush*
Carl
Member #: 95
liverpool-on-sea
did a similar thing in my youth, lol. fittted accesory automatic window closers i.e leave your windows open set your alarm and it closes windows. anyway i needed a feed to trigger the box of tricks. only one i could find was from my indicators, wired it up tried it on the drive lots of times brilliant, well cool. at the time lol
any hows goes for a drive radio on full belt, windows open etc. etc indicated to turn a corner, window goes up nearley took my mates arm off. lol.
carl you've got a hillarious story for every occasion
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Easier to connect to side lights ....... just a thought.
