| Home > General Chat > much power!possible? | |||||||
18th Dec, 2006 at 03:37:30pm
Hi
18th Dec, 2006 at 04:17:07pm
Yes, that is a lot of torque... Unless he dyno'd it in 3rd of course!!!
18th Dec, 2006 at 04:31:09pm
I have dynoed my car both in 4th and in 3rd on the same rollers as he used, and it was no difference...So it shouldnt matter on these rollers I think. But I do understand your point. Edited by miniminor63 on 18th Dec, 2006. |
3596 Posts Member #: 655 Post Whore Northern Ireland |
18th Dec, 2006 at 06:11:37pm
strictly speaking gear shouldnt matter too much....
19th Dec, 2006 at 08:24:23am
Yes, what clutch is the guy running? He's running 8X13" wheels AFAICR.
19th Dec, 2006 at 08:27:06am
he is running some very wide 12" at the moment I think |
703 Posts Member #: 105 1st to provide proof of a running Bimmy Conversion! Brisbane ,Australia |
19th Dec, 2006 at 12:48:00pm
welll Motec is Australian produced you see www.miniman.com.au
19th Dec, 2006 at 07:13:39pm
Shouldnt matter what gear. The dyno should be able to sort that out, as it knows what rpm's are being used ( at the dyno ) and what torque is being created.
19th Dec, 2006 at 10:16:12pm
yes that is what I mean too. |
86 Posts Member #: 631 Advanced Member Thames valley |
21st Dec, 2006 at 12:34:59pm
I like my dyno better than anyone elses tho,,, mine gives out power readings like-- > "Nah, that`s crap, go fix all this wrong stuff & come back later" & > " hey that`s not bad for a stock std mini, nice" & > Now we`re talking, that`s a nice big bore" & "Ok, now we have mumbo Yay!!!" & this is the one i like > "Holy shit batman, this thing cranks!!!" Now that`s my dyno & it`s located just under my back bone but just a tad behind my balls
& i`d have to say that the torque will be higher in 3rd as opposed to 4th gear, just the same as the torque in first gear is greater than in 2nd etc,,, that`s the point of having gears sorry, just muckin around i`ll shut up now
Yeah i know just what you mean mad matt, i put me boost up the other day and set off hard ,broke the back of the seat .That was a surprise i can tell you . Cor the power .Great measurement though.......Hows the weather....ha ha I know , i know im sorry , it just makes me grin !!!
21st Dec, 2006 at 02:14:37pm
Queensland,,, ---> beautifull one day...--> perfect the next,,, then pissing down rain www.miniman.com.au
21st Dec, 2006 at 03:22:30pm
Okay, got a little more info here. The car is owned by a guy working for a tuning company here. I talked to the owner of the company last time (who built the car), and talked to the owner of the car himself today. He did not want to stand behind the numbers given above as they where from rollers seldom calibrated (mostly used for mapping only).
Edited by miniminor63 on 21st Dec, 2006. |
21st Dec, 2006 at 07:36:24pm
On 21st of Dec, 2006 at 03:22pm miniminor63 said:
He fires the injector closest to the rad to cylinder two and the one next to it to cylinder one. (interesting aproach). Doing it this way meant that he had no obvious troubles with charge steal appearantly... He is running 1.8 bars of boost! So he aims te injector at the valve ?? Is that such a strange thing to do ? Given the problems A-series appear to have, firing an injector in the middle, seems like the very wrong thing to do...yet everyone still does it ?? 9.85 @ 145mph
21st Dec, 2006 at 08:06:07pm
Well, the power and boost sound correct at least!!!
Edited by turbodave16v on 21st Dec, 2006. On 17th Nov, 2014 Tom Fenton said:
21st Dec, 2006 at 11:19:21pm
he has done some testing on cylinder mixture, and he is going to take the engine out and put it on a dyno with facilities for EGT at each cylinder for example. Then he will get the real ansere... Will post if I hear how it goes |
22nd Dec, 2006 at 12:49:21am
The EGT will be pretty inconclusive - as the middle branch will always run hotter than the outers; no matter what you do.
22nd Dec, 2006 at 08:07:46am
I know, but he where going to do other tests too... but point being what I think is interesting about this is that these guys arent really into minis, but they know their stuff when it comes to tuning... They have a bit different aproach to what we are used too, so I find it interested to see how it works. And it looks to be working pretty okay at the moment. |
23rd Dec, 2006 at 11:14:23am
I asked this on another thread....and I'll ask again.
23rd Dec, 2006 at 01:52:58pm
Sequential isn't enough for the 5 porter ... you need to be able to stagger the timing across each cylinder irregularly to get around the charge robbing. You will need to change this staggered timing as the revs increase I guess.
Edited by RogerM on 23rd Dec, 2006. Every day is a school day ...........
23rd Dec, 2006 at 03:12:25pm
On 23rd of Dec, 2006 at 01:52pm RogerM said:
Or go for 4 inlet ports .... ![]() I thought about it.....but it wouldnt be a proper A-series anymore.... So in an ideal world, we need a sequential system, firing at the valve with a suitably accurate injector, and individual cylinder inj timing control.... Cant be that hard can it lol. 9.85 @ 145mph
23rd Dec, 2006 at 04:23:14pm
Or semi -sequential with seperate firing angles. Also brings back the question of how with something like 150-crank degrees of clear, non charge-stealed, realistically open valve do you actually get enough fuel into the engine and still have enough for huge power? Edited by turbodave16v on 23rd Dec, 2006. On 17th Nov, 2014 Tom Fenton said:
23rd Dec, 2006 at 05:35:07pm
Anyone for a direct injection A-series lol 9.85 @ 145mph
23rd Dec, 2006 at 09:37:02pm
Time for MS2 and the special code ... might be quicker to go 4 inlets though.
24th Dec, 2006 at 12:43:04pm
7 port would be the easy option... 9.85 @ 145mph
25th Dec, 2006 at 01:28:14pm
yes, Autronic is fully sequential, we run 2 of them in the litre sprint speedway cars,,, Motec & Autronic people actually used to be partners in crime & split up,,,then made the 2 sperate companies, & yes both good Aussie made stuff www.miniman.com.au
) talked about a mini here in Norway that used a motec ECU.
