Home > General Chat > vented discs under 10" wheels
JT
Member #: 637
Hertfordshire
hi
iv done a search and think i understand whats needed but just need to make a few things clearer...
i have minispares 4 alloy pots for 10" wheels, with standerd 8.4 discs ground down to 7.5.
what i plan on doing is fitting some vented metro discs for when i put the turbo in to improve it all a bit!!
am i correct in thinking i need the following bits:
http://www.minispares.com/Product.aspx?pid=36942
is that for 2 or just 1??
http://www.minispares.com/Product.aspx?pid=34034
are these worth it or is it not worth it after there ground down to 7.5"
http://www.minispares.com/Product.aspx?pid=33487
if i do the following will it all still fit ok under my 6x10 J wheels?
is there anything else i will need?
sorry for the long post
merry xmas!!
josh
My build thread..
giallofly
Member #: 164
The Stig..
Newport Pagnell
To be honest you realy do not need vented.....
I have never boiled up my 7.5 solid discs on a trackday, maye on all out racing you may need vented but only maybe.
JF.
MINIMON
Member #: 863
Lathom, lancs
i would just get the adapter from minispeed to convert 4 pot alloy non vented calipers to vented ones
RED850
Member #: 89
Sydney Australia
i have this kit on mine, but see in the vented caliper kit you have the spacers that go in the middle of the caliper to space out the 2 sides but you also have 4 spacer washes, i did not use these and do not know where they go, my disc sits in the middle of the caliper and the pistons sit out from the caliper the same amount each side so the caliper does not need to be spaced inwards at all.
anyone got ideas on this?
179hp on 12psi 1293cc of pure A series
14.0et @101 mph
i used these under the bolt head so the 'soft' alloy caliper body isnt damaged by the cap head:
you can see here the difference between the vented and non vented alloy calipers (just a spacer):
and the required, thinner, vented flange to pull the fatter disc out a little more:
joe
i believe those spacers you talk about are theyre for when non vented set ups are used to get it central on the disc
possibly, but but i dont remember using them?
maybe they could be used for people running vented discs, but non vented drive flanges?
er....head hurts
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I can't get any decent brakes under my reverse rims without silly wheel spacers.
On 7th Nov, 2008 Nic said:
naeJ
m
Jay#2
Member #: 648
Edited by Jay#2 on 21st Dec, 2006.
naeJ
m
Minimad69
Member #: 1311
Yeovil, Somerset
i use alloy 4 pots with vented discs on standard hubs with no spacers. they are dead central and fit nicely under my 10" rims
JT
Member #: 637
Hertfordshire
do you get better pedal feel or better brake performance?
would you think its worth doing?
atm i just have standerd discs ground down to 7.5" and im using minispares 4pots.
cheers
josh
My build thread..
RED850
Member #: 89
Sydney Australia
HHHm interesting,
i do not have a vented flange i have a thick flange, see pics, very crap with phone camera, maybe the spacer is for under the bolt head.
my calipers are central to the disc
and with manbas i needed an 8mm spacer to fit them over the caliper nipple, if i remove the nipple i do not even need a spacer but i have not brakes he he.
i think the mini sport 4 pots have nipples in different spots.
anyone got a pics of the mini sport ones?
14.0et @101 mph
