Home > Help Needed / General Tech Chat > Still smelling petrol inside??
Zeemax Power
Member #: 393
Oulton Park
Hi have a problem with petrol smell in car its worse when let standing eg when coming to it in an morning. The smell seemed to becoming from the back. So i changed the tank, put a big brever on and kept the old one as well, gasket glued the rub gaket round the fuel pump, and also i brought some bonding silcon and did all the places you can think aswell as round the cap so it shouldn't be coming in. Though i haven't sloved the problem you can't smell petrol the same as you could special while driving has got alot better. I did the conversion from spi and kept the fuel lines i was wondering is this anyway anything to do with it. Any ideas greatiful cos i'm running out them fast.
Thanx
http://www.Zeemax.com
replace the rubber seal on the tank sender these only cost pence and check all your hoses again
Dangerous
Member #: 417
Check the bottom of the carb,the rubber seal goes rock hard(especially if no heat sheid) and leaks straight onto the exhaust
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Are you filling the tank right up to the top when you leave it? I have a fuel smell if i fill mine right up, i put a maximum of £12 in each time
try spraying all joints your worried about with a can of gloss paint ,just a light coat , then look at it in the morn ,if its leaking then youll see the paint crackling bubbling up .
regards robert.
