Home > Technical Chat > Valve on carb
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
On the throttle valve on my carb there is a spring and spiggot. Just wonding what is it and what does it do? Does it affect performance of the engine?
most people will advise you to swap it for a solid butterfly disc and get a dump valve.
Turbo Shed
Member #: 30
Epsom, Surrey
whats it got to do with a dump valve? they fit them to none turbo cars as well.
to help dissipate the boost when you snap the throttle shut
Quite a lot if your dumpvalve has a heavy spring in it... It'll open really slowly, giving a nice whooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooosh instead of a WHOOOOSH.
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Which one sounds less like a toilet flush? with the solid butterfly?
I want to get a "whi-tsssssh" noise!
Edited by jamesfawcett on 20th Dec, 2006.
Turbo Shed
Member #: 30
Epsom, Surrey
you could record your own noise and play it back on a PA system when you change gear
or just get a mate to lean out the window and make the noise of your choice
LOL!
JT
Member #: 637
Hertfordshire
so were would you get a solid butterfly disc from?
iv looked on avonbar with no joy!
cheers
josh
My build thread..
nogin
Member #: 487
westbury, wiltshire
from a carb with a solid butterfly or a rebuild kit as these have them in
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
Or dump the spring and solder up the hole.
metroturbo
Member #: 989
North Yorkshire
It is there to reduce hydrocarbon emissions on overrun.
Jordan
Member #: 1392
Well what is the purpose of the spring?
IIRC on all cars it helps prevent over run, also I think it helps prevent turbo stall. If your engine is set-up properly and looked after over run shouldn't be an issue, and if you've got a DV turbo stall shouldn't be an issue either, so you might as well go for a solid disk as the valve impedes the air flow in the carb.
