Home > Help Needed / General Tech Chat > Manifold Pressure with Megajolt
LukeAnsley
Member #: 193
I have just got the megajolt up and running, and all seems ok so far. Only had it running for a few minutes though.
Just wondering what sort of reading people have for the MAP sensor when the engine is idling? Its seems to be above the 90KPa when my car is idling. Is this right or should it be lower? Just wondering as i brought the megajolt board from someone at work, and wanted to make sure it's reading right.
Thanks
Luke
colas
Member #: 102
Pennsylvania USA
Yeah Thats about what mine does.
Ben H
Member #: 184
Melton Mowbray, Pie Country
All cars are different and it depends on the cam quite a lot. I wouldn't worry about the idle too much. If it goes to near enough 100 at WOT (NA obviously) and to about 20 or 30 on the over run then it is fine.
http://www.twin-turbo.co.uk
