Home > Help Needed / General Tech Chat > please,help frenchie
frenchie
Member #: 1429
france Nimes
hi,i've got a lot of problems whith my turbo motor:
i change the carb(whith teh rebuild kit),new fuel pump,new presure regulator,igntion,coil etc......and it still running bad.
Poor starting,idle pumping like a 205 pug,and the richness on the carb is turn full in.
i'm fed up whith this motor,and i need help.
thanks
Ric
Member #: 36
Basingstoke
There's a section in either beginners tech or FAQ, can't remember which, by turbodave. Goes through all the common running faults. Sounds to me like you've got a split in a vac hose somewhere.
Have a read of that, have a play and keep us informed.
frenchie
Member #: 1429
france Nimes
thanks for your reply,i read the faq but can't find my problem.
frenchie,
if you have checked all the other possabilitys out and its still the same
it could be the carb mixture is too lean if you have the carb turned full in
please tell us why? you rebuilt the carb and give us more information regarding the problem you have
regards ben
frenchie
Member #: 1429
france Nimes
ben,
i rebuild the carb with the su repair kit and dismantling it plenty off.
i know i'm running too lean but the plugs are black and full of petrol.
the iddle run at 1500 trs for 30 seconds and up to 3000 after and again 1500 etc....
i use 6mm fuel in line but 8mm return,should i use 8mm for in and out?
was the car running ok before you rebuilt the carb ?
if it was ok, then the problem may lie with the carb float bowl JET not seating correctley!
did you replace all the parts as you mentioned to cure a problem that was already there frenchie ?
Edited by BENROSS on 22nd Dec, 2006.
You need to ask user 'fab' for his assistance - maybe ask him to come and spend some time helping you - in excahnce for some beer?
frenchie
Member #: 1429
france Nimes
it will be diffucult for Fab to come house,because i live in france.
i replace a new float ball suplied in the kit,new jet and new needle.
thi motor was in another mini and won't run good before.
i strip down it and pull in my car.
this morning i dismentled all the carb and turbo to check all gasket and the wastegate.
USER FAB
Member #: 100
Parisien Turbo Expert
Last line of his addres (at least his address of 2004) was 95100 Argenteuil... Hopefully that means something to you!
Edited by turbodave16v on 22nd Dec, 2006.
Fab lives about 450 miles from Nimes then!
have you checked the fuel pressure since changing the regulator?
are you only having these problems since rebuilding the carb? or where they there before?
Well he can maybe call and discuss his problem? LOL!
i had a similar prob with the carb , it was the choke seals leaking have a good look at the choke drum ,the brass thing in the hole ,and see if it had hardened rubber seals , or if it has a groove worn in it . ,if so ,try to smooth it off and carefully insert new seals , making sure they go in the right way round ,.
maybe that will make a differance ?
regards robert
blown_imp
Member #: 598
Gaol
Yeah my choke seals were buggered on the turbo imp, it would run fine one moment then super rich. It was the choke just letting in an unmetered amount of fuel on and off!
Def check that out, pretty simple job.
J
On 5th of Sep, 2006 at 05:47pm mini13 said:
I reckon if his brains were gunpowder he couldn't blow his own hat off...
frenchie
Member #: 1429
france Nimes
this afternoon i dismantling the carb and replace the choke by another one taken on another HIF44.
i didn't control the regulator,i suppose it's checked at the factory no?it's a new one.
fab
Member #: 100
Paris\' suburb
well,
just get your pm,
I think that "too lean but the plugs are black and full of petrol" are not going togethers
if you're not in a hurry send me your phone number by email, I'll phone you in the first days of january.
if you are , I'lll help you by mail
regards
fab
welshdan
Member #: 1111
s wales
ever seen sharpe?*wink*
fab
Member #: 100
Paris\' suburb
me?
no........
just realist
no its not, unless you were lucky
it needs to be set with a gauge to 3.5psi at idle
