| Home > Help Needed / General Tech Chat > Turbo dizzy wiring | |||||||
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
22nd Dec, 2006 at 10:30:13am
Hi everyone. I have the late turbo dizzy fitted to my engine(the one with the amplifier module on the side). Firstly I had it connected to 12v but with the engine running this obviously goes up to 14.6volts, so was blowing up modules. it's now connected to the ballast resistor wire, so runs at the right voltage.
22nd Dec, 2006 at 07:59:26pm
it's taken from the stater solenoid
1300 Posts Member #: 829 Post Whore essex |
23rd Dec, 2006 at 12:05:42am
The output on your alternator is a bit high 1293 Turbo mini
23rd Dec, 2006 at 01:19:37pm
jimmy i thought this was normal for when the engine was running?
24th Dec, 2006 at 01:41:40pm
The alternator voltage will goto 14.2 output 1293 Turbo mini
54 Posts Member #: 1425 Advanced Member Yorkshire Wolds |
24th Dec, 2006 at 05:07:30pm
Make sure you use the right ignition coil! there are different types with different impedances!! The wrong type will draw to much current hence blow your module.
