Home > Help Needed / General Tech Chat > .
Bodge Job
Member #: 953
London
Edited by Bodge Job on 31st Mar, 2007.
what happens if you leave the engine to idle for 15 mins from cold with the rad cap off,, assuming its warmed up after 10 mins, does any water bubble out of the rad cap if its left to idle, is the rad filled to its max mark. who changed the HG.
Bodge Job
Member #: 953
London
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Does the water level go down any, like are you loosing it? The bubbling rad sounds like you still have a head gasket prob. What was the block/head surfaces like?
On 7th Nov, 2008 Nic said:
naeJ
m
Bodge Job
Member #: 953
London
this may be normal jim with the rad top off
my moneys on the ignition leads you may have mixed up
look at this first
Bodge Job
Member #: 953
London
Jay#2
Member #: 648
A few questions:
Where did the head gasket blow (into a water cavity or between cylinders)? What is the noise that you hear, is it noisy lifters I take it? So is it backfiring through the carb you say?
Cutting out is a fuel/spark problem. Not starting afterwards sounds like fuel delivery probs and would make sense if you changed the fuel tank. Are you using the in tank fuel pump and are you sure it works fine? As you say check all plug leads but make sure you haven't nipped something between the head and block (I did that once!).
naeJ
m
Bodge Job
Member #: 953
London
sure you have used the right clearances?
They do tap, maybe they're just set wider than they were before (i.e. correctly or incorrectly now) and with all the other problems you think it sounds a lot worse?
I know noises can appear after something else goes wrong, your always looking for stuff whereas before you just drive it!
does it run evenly?
Tappet clearances could be causing the effects you describe.
Bodge Job
Member #: 953
London
Jay#2
Member #: 648
What happens if you set your valve clearance tighter than the manual says? Does it get any quieter? I'm not saying this is the solution but the rocker tips are worn on my car and they are noisy unless I set them a little tighter. Are you sure you didn't pull a lifter out of it's bore when you pulled the head? Maybe you can't do this with a 1275 but I did it once on my 998. Also are you sure your rockers aren't hitting the rocker cover, like is it quiet with the cover off?
naeJ
m
Bodge Job
Member #: 953
London
Bodge Job
Member #: 953
London
Dangerous
Member #: 417
If they are smaller than .012" they won't shut properly when the engine is hot.
Jay#2
Member #: 648
Your right but at least it will show that all the lfters are in place and nothing serious is amis, I just mean to try it and not leave it like this. In reality when you set the clearances the feeler gauge goes between the valve stem and the part of the tip that doesn't wipe the valve stem. i.e the clearance might be text book at this part of the rocker but the the part of the tip that makes contact is worn and hollowed a bit there is more slack there. This sounds confusing!
naeJ
m
blown_imp
Member #: 598
Gaol
The head gasket problems could be a warped head?
On 5th of Sep, 2006 at 05:47pm mini13 said:
I reckon if his brains were gunpowder he couldn't blow his own hat off...
0.012" is to allow for the wear
jimmy hove you checked the compression ratio
also is the engine firing on all 4 spark plugs ?
by removing the leads one by one to see if the engine dies
is there anyone who lives near jimmy who could take a look ????
Bodge Job
Member #: 953
London
Bodge Job
Member #: 953
London
Bodge Job
Member #: 953
London
On 31st of Dec, 2006 at 11:32pm jimmy1293 said:
did what BENROSS said and I had put the leads wrong way round (3&2 were put 3&2) from the cap, as I changed it with a new one which fixed the backfireing and missing.
Glade it's running OK now. You're not the first person to do this an I'm sure you won't be the last. A lot of people muddle up 2&3, just remember that the dizzy spins anti-clockwise.
