| Home > Help Needed / General Tech Chat > lambda gauge shows 10:1 afr missfiring | |||||||
27th Dec, 2006 at 10:00:59pm
lambda gauge shows 10:1 afr under full load, boost 12 to 13 psi missfiring only on full monte! takes about 10 seconds to develope
27th Dec, 2006 at 10:10:09pm
surely that suggests it sover fueling badly as its takeing time to foul the plugs. |
27th Dec, 2006 at 10:48:46pm
yes carl i would agree
27th Dec, 2006 at 10:48:53pm
missfires will usually show a lean reading on a wideband, due to excess oxygen going thru the engine.....
27th Dec, 2006 at 10:51:12pm
stevie, perfect 12.5 to 13:1
27th Dec, 2006 at 11:48:29pm
12.5:1 is only perfect for full power
AlexF |
27th Dec, 2006 at 11:57:59pm
Its very odd that its so rich even with the standard needle.........
28th Dec, 2006 at 12:08:27am
Jim had the same thing with his last engine I recall - an un-modified BDD needle... It shouldn't have worked, but it did...
28th Dec, 2006 at 12:09:53am
Everyones different, but I wouldnt trust a turbo car at 12.5:1
28th Dec, 2006 at 09:36:51am
could be your coil which i had a problem with also my float needle in the carb was leaking when on boost which resulted in the car running rich and holing back and misfiring. always looking for them bigger bunches of bannanas |
28th Dec, 2006 at 02:41:04pm
''timing standard turbo dizzy set 6 deg BTDC ''
28th Dec, 2006 at 09:40:37pm
fuel pressure ok tom
29th Dec, 2006 at 08:56:23am
i would still check your float valve, mine was fine untill i up the boost then the fuel would piss past the valve causing fuel to come up the main jet hole..
29th Dec, 2006 at 12:05:33pm
thanks hoggy will check that out buddy
