| Home > General Chat > engine part numbers | |||||||
![]() 213 Posts Member #: 249 Senior Member |
6th May, 2004 at 03:09:58pm
hi...please help...where is the engine number on the block,head and crank so i can check what ive got??? |
![]() 164 Posts Member #: 206 Advanced Member Milton Keynes |
6th May, 2004 at 03:13:34pm
block: below wher the thermostat would be
9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked |
6th May, 2004 at 03:43:06pm
block: below wher the thermostat would be Head: in the middle of the casting crank: On one of the webs cheers,just had look and could find nothing in those places but found these other numbers BLOCK -- wfm 1024 mains caps -- 12g1429 +12g1433..nothing on steel ceentre strap HEAD -- 6e7 near to thermostat ... stamped med1308t CRANK -- various numbers on web ....cam6232....bsv925....a_ d8cg any ideas regards mark |
6th May, 2004 at 03:51:12pm
I think wrm1024 is a late A+ block, you should se a 12h number just below the thermostat
6th May, 2004 at 04:03:37pm
where was the engine block number
AlexF |
6th May, 2004 at 04:35:14pm
Make it ovious!!! - The engine number on the protruding section of block behind where the alternator sits. Having an MED head, probably means the engine is rebuilt, and the original number has long gone!
6th May, 2004 at 06:12:37pm
thanks for the help guys...i need to i.d this engine to decide which one to proceed with for car...i have this recent rebuilt one and a defo metro turbo engine in car but is worn out....got some more info and after a bit of research it looks good
6th May, 2004 at 06:52:34pm
Mark is all late metro stuff, the right stuff. The MED 1308t or whatever is there own stamp, 12g940 is the head number that is important. Often the engines are built with whatever is about, not always rebuilt from an MG metro itself.
Edited by giallofly on 6th May, 2004. On 21st Jan, 2011 fastcarl said:
6th May, 2004 at 09:15:09pm
might be worth identifing the pistons in your block to are they turbo ones? no longer a series, but still 1.3 turbo.
6th May, 2004 at 09:34:34pm
hi jon,i know we discussed the spec but im interested in learning to be able to identify the different parts myself...i now am 99% sure its a turbo block as it has the centre tangs for main bearing location,which apparently is unique to the turbo lump.......as its quite new im going for 15 cc forged omegas instead of the 10 cc omegas in there now,so just wanted to see if i can identify the rods and crank to make sure they are turbo items so i have good strength...i want to build this engine once and want it to last! its 18 yrs since i had a mini so ive forgoten lots!
6th May, 2004 at 10:05:04pm
post 89 blocks also had the central tang for the mains if i remember correctly.
7th May, 2004 at 09:27:20am
Stand Corrected, Jon is right with the cranks.
